car runs but will only start on full choke then down to half, when put right in car continues to run on fast idle, 'blip' the throttle though and it drops to a 'normal' idle or more often than not stalls, i have no tachometer, is it possible fuel set wrong?
will look at this post tomorrow gudnite
engine trouble
mini-mad-dan
, Jan 11 2006 10:40 PM
Posted 11 January 2006 - 10:40 PM
Posted 11 January 2006 - 10:45 PM
lube up the linkages
dave
dave
Posted 11 January 2006 - 11:10 PM
Had your MOT done recently?? They may have fiddled with the mixture... failing that, lube away!
Posted 12 January 2006 - 07:01 AM
nope mot done a year an a abit ago-faild- am doing work myself, and yes my dad fiddled with the fueling, suppose my only choice is to have it set up properly as soon as possible, p.s the linkages could easaly be the problem as wet cats have been sleeping on my engine(no bonnet)
Posted 12 January 2006 - 08:24 AM
As it sounds like the cars been standing for a while, the it's quite likelt that dust and debris has settled on it. A good clean may not go a miss.
