Engine Suddenly Dies But Then Starts And Runs Fine 5 Mins Later...
19 replies to this topic
#1 Ozymandias
Ozymandias
  • 281 posts
Posted 04 May 2011 - 10:17 AM
Model:1.3 Cooper SPI
Year: 1995
In traffic, coasting downhill (low revs, in gear, foot off clutch) - suddenly the motor just dies. Engine turns fine but won't fire - then 2 mins later she bursts into life and off we go... this is the second time this has happened!
I've had the inline fuel filter replaced - could it be an electrical fault or that my fuel pump is beginning to go? I've been having problems with the battery draining if left for a few days as well, not sure if this would have anything to do with it.
Any bright ideas gratefully received!
#2 jonspeed 1400 sprint
  • 17 posts
Posted 04 May 2011 - 10:27 AM
Ignition or fueling as you are already aware, fuel pumps do tend so show faults at low speed. If the fault has shown only since the filter was replaced, have a good look at the new filter, I cant remember if they can be fitted the wrong way round.............could pass fuel but be retrictive.
Good luck
John.
#3 Ozymandias
Ozymandias
  • 281 posts
Posted 04 May 2011 - 10:31 AM
Good luck
John.
Thanks for your reply, John - just to clarify that the fault happened before the filter was replaced, so I don't think it's that - maybe it's the pump... :)(
#4 Sheikh Pip
Sheikh Pip
  • 239 posts
  • Local Club: Sutton Coldfield Mini Club
Posted 04 May 2011 - 04:32 PM
Have you checked the petrol tank breather?
Good luck
John.
#5 Ozymandias
Ozymandias
  • 281 posts
Posted 04 May 2011 - 04:40 PM
[quote name='Sheikh Pip' date='May 4 2011, 05:32 PM' post='2120520']
Not yet - will do! Thanks! :)
#6 sx_turbo
sx_turbo
  • 214 posts
Posted 05 May 2011 - 10:38 AM
possible ecu temp sensor
#7 Ozymandias
Ozymandias
  • 281 posts
Posted 09 May 2011 - 04:37 PM
That sounds expensive/difficult to fix... :D
#8 somaaada
somaaada
    Just On Tickover
  • 5 posts
Posted 09 May 2011 - 05:54 PM
hey everibody, i just buy one mini 1.3i from 1996 and i have a problam with it...
the car drives great but sometimes wen i stop by a trafic light and he is on 1000rpm it will sop from alone and then i will not start again in the next few minuts, i meen it starts but it seems that something is cuting the petrol or something from it because he will work like 5 seconds and it will stop again, it does that for some minuts and then it will start and drive normal again....
in the oather day i drive more than 150 km withaut any problam but wen i get to the city i was in a trafic light it stop again and no chanc to started, i try like 20 times and no chance, afther sometime it just start normal again
for exemple if i leth the engine worm up the car will work good but every 4 or 5 minuts it will stop from alone and then it dont wont to start again
the strange is that if you drive always in the higway he never stops...
can somebody help me please??
sorry abaut my inglish
greatings Cardoso
#9 Ozymandias
Ozymandias
  • 281 posts
Posted 24 May 2011 - 09:45 AM
Is there any way I can check if it's this? How/why would the temp sensor cause the engine to stop?(please explain in "for idiot" terms...! :)
#10 sx_turbo
sx_turbo
  • 214 posts
Posted 24 May 2011 - 09:52 AM
the ecu relies on readings from sensors, there are various sensors on the car that tells the ecu what to do,
when one of these sensors breaks down the ecu gets confused and can cause running issues.
the sensors arent very expensive so you could change it as par the cause trying to diagnose problems,
or you could get some boiling water and a multi meter (i'm not entirley sure on the exact values you should be seeing so this is as far as i cant tell you im afraid)
#11 Ozymandias
Ozymandias
  • 281 posts
Posted 24 May 2011 - 09:58 AM
Brilliant - thanks! :)
#12 sx_turbo
sx_turbo
  • 214 posts
Posted 24 May 2011 - 10:16 AM
also forgot to add,
the fact that you only seem to have problems when the car gets hot, and is then fine when it has cooled down again points to the ecu temp,
#13 DanRobinson
DanRobinson
  • 138 posts
Posted 24 May 2011 - 10:18 AM
Was it raining at all? that sounds like classic water in the dizzy sydrome. starts up fine 2 mins after cutting out.
#14 sx_turbo
sx_turbo
  • 214 posts
Posted 24 May 2011 - 10:21 AM
just had a look at the price of them at work and there only £12.50 for a new one, and there dead easy to fit, providing there easy to get to,
#15 Ozymandias
Ozymandias
  • 281 posts
Posted 24 May 2011 - 10:40 AM
No, it's been dry as a bone all three times she's stopped (she's bathed in WD40 anyway...) :)
