Filters or trumpet things?
johnnysti
, Jan 11 2006 10:52 PM
10 replies to this topic
Posted 11 January 2006 - 10:52 PM
Right
Managed to find a weber 45 with all the bits!!
Its got a K&N filter with it but was wondering what the difference is with having a filter or using the trumpet things? Also its got two linkages? Why will it have two?
Thanks gang
Johnny
Thanks gang
Johnny
Posted 11 January 2006 - 11:30 PM
By the trumpet things do you mean ram pipes? If so then expect to rebuild your engine every 2500 miles.
Posted 11 January 2006 - 11:42 PM
Use them both, if the filter is deep enough, fit the ram pipes on the in side of the filter. Webber K&N filters come in varying lengths so you can successfully install ram pipes on the inside without restricting the air.
Posted 12 January 2006 - 07:17 AM
It comes with two different size filters.
Cant you get sock like filters to put over ram pipes, like the itg ones (i think thats what they are??)
I really dont fancy rebuilding the engine every 2.5k miles!!
Johnny
Johnny
Posted 12 January 2006 - 10:10 AM
You using a webber 45, which should be on a long manifold, therefore a webber box, and ram pipes, and a filter, not sure on dimensions, but I hope that all fits in the webber box!
Posted 12 January 2006 - 07:26 PM
Its on a 6" manifold and the two filter that comes with are different lengths
Posted 13 January 2006 - 12:19 PM
Yes you can get those ITG sock things, i think pipercross make them too. that is probably what ill buy using on my weber, since using ram pipes inside a k&n filter must be quite restrictive?, plus it uses less room!
Posted 13 January 2006 - 01:47 PM
To be honest, I don't think you'll really need ram pipes on a 45, I certainly didn't!
Posted 13 January 2006 - 01:59 PM
You're prolly right JB. Mine came with some ram pipes, but I am gonna experiment with them and some socks that we have at work.To be honest, I don't think you'll really need ram pipes on a 45, I certainly didn't!
BUT:
When I took the carb into a Weber specialist he said that he had seen losses of up to 10BHP on single 45 DCOEs using filter socks and ram pipes and that 'in his opinion' a big K and N or similar should flow better. He did say though that if racing, he would run without filters :saywhat:
Posted 13 January 2006 - 02:01 PM
Yea, but when racing you'll rebuild at least once a season!
Posted 13 January 2006 - 02:06 PM
Aiii, this is true, NOT AT ALL recommended for normal use!Yea, but when racing you'll rebuild at least once a season!
