Drive shafts
Posted 12 January 2006 - 07:38 AM
Has anyone ever compared the two types? I am missing a shaft from a disc setup but have 2 sets of drum shafts, but without the missing shaft to compare against, I don't know if they will be the same.
Posted 12 January 2006 - 08:17 AM
Posted 12 January 2006 - 09:47 AM
Posted 12 January 2006 - 09:14 PM
If thats the case I don't need to buy a new one as I can just use the drum set right? (obviusly I shal change the outer CV)
Posted 12 January 2006 - 10:04 PM
Posted 12 January 2006 - 10:06 PM
Duh....just re-read your post ! :tongue:So other than possible thickness differences, there is no difference between disk and drum shafts, the splines are the same for both at each end?
Posted 12 January 2006 - 10:08 PM
The nut and split pins and everything are fitted to the CV joint, not the driveshaft.
Posted 13 January 2006 - 09:53 AM
dave
Posted 13 January 2006 - 11:16 AM
does anyone know up to which power the drum brakes shafts can be used?
Harald
Posted 13 January 2006 - 01:41 PM
dave
Posted 24 July 2006 - 03:47 PM
after a bit of a brake falier, i was thinking of fitting some disks to the front of my Elf, i've already got a spare set of disk hubs with cv's, and was thinking of using the mini spares 12" to 10" conversion clicky but was unsure if the rubber coupling /drum drive shafts would fit the disk type cv joint.
seems all will be ok going by the above posts
Si
