Hi,
I have recently completed my megajolt instalation but am unable to get it to connect to my laptop. I have followed the instructions given but it says "could not open port" at the bottom of the programe. I am running widows vista with a serial to use converter.
I have also notivced that the rev counter doesn't always work and when I use a timing light the ignition advance stayes fixed.
any help/advice would be much appreciated.
thanks
Matt
Megajolt Problem
matty121
, May 05 2011 04:05 PM
6 replies to this topic
Posted 05 May 2011 - 04:05 PM
Posted 05 May 2011 - 04:20 PM
Have you made sure you are using the correct com port?
Some USB adapters aren't compatible so it might be worth trying it on a proper RS232 serial port.
Also, the MJ does have power?
Posted 05 May 2011 - 04:21 PM
I have to say with the lack of Advance and the non-communication I don't think the Megajolt unit is receiving power
Posted 05 May 2011 - 05:24 PM
I have powered the megajolt through the existing cable that went to the ignition coil, the green led does light up when the ignition is on maybe needs a direct power feed from the battery?
Posted 05 May 2011 - 06:44 PM
there are only a handfull of serial to USB convertors that seem to work with the megajolt unit.
search the internet for megajolt and it should bring up a site that lists where to get ones that work from
Posted 05 May 2011 - 07:32 PM
It also depends on what map is installed on the MJ unit as to whether the advance will do anything. It depends if the map is installed or just at blanket advance.
I use a belkin USB to com adaptor, and managed to download a driver for windows 7 and it works fine, but I have heard of other adaptors causing problems, try the autolabs forum.
Are you using MAP or TPS as it may be affecting the advance, or the PIP and SAW wires not being connected correctly.
Get the comms sorted and the rest should become apparent.
Posted 06 May 2011 - 12:01 AM
If the led is on then there's electrickery reaching the MJ & it ought to register with your computer. I'd try & sort that one first.
If you haven't already, open up device manager on your pc; find your adapter in the com & LPT list and make sure you have the same one selected in the configurator software. You can also try reducing the baud rate for the port (double click it in device manager).
