Verto Or Pre Verto
31 replies to this topic
#1 booton
booton
  • 913 posts
Posted 06 May 2011 - 08:33 PM
ok just about to finish my engine.
i have a verto and non verto complete set up.
unsure which one to choose.
i know u adjust the pre verto, but
the verto seems a better design.
what types are people using with their tunned engines thanks steve
#2 bmcecosse
bmcecosse
  • 9,699 posts
Posted 06 May 2011 - 08:35 PM
I ALWAYS used the PRE-verto - with an orange diaphragm.
#3 Cooperman
  • 23,294 posts
Posted 06 May 2011 - 08:52 PM
+1 on that.
#4 booton
booton
  • 913 posts
Posted 06 May 2011 - 09:00 PM
so u also use the older inetia type starter rather than a pre engaged.
#5 bmcecosse
bmcecosse
  • 9,699 posts
Posted 06 May 2011 - 09:08 PM
Correct!
#6 Cooperman
  • 23,294 posts
Posted 06 May 2011 - 09:13 PM
Correct!
Then you can fit an oil cooler without having to spacer the grille forward so that the cooler can clear the starter solenoid on the pre-engaged type.
#7 mini13
mini13
  • 3,810 posts
Posted 06 May 2011 - 09:14 PM
I'm a fan of the verto, but its not possible to get it a light as the pre verto style,
I'd say for revy race type engines go preverto, for proper torque monsters like 200hp+ turbo engines go verto and customise it with two springs ,
#8 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 06 May 2011 - 09:53 PM
Times are changing, and some are going to get lost in the dust holding on to their pre verto flywheels and inertia starter motors :)
RTS Verto clutch and high torque starters are where its at! :P
#9 bmcecosse
bmcecosse
  • 9,699 posts
Posted 06 May 2011 - 10:19 PM
#10 booton
booton
  • 913 posts
Posted 07 May 2011 - 08:18 AM
which one is lighter standard, as the less weight the better really. can;t afford to buy a light weight one yet.
my verto on is on an engine don;t really want to take it of just to get a rough weight.
#11 bmcecosse
bmcecosse
  • 9,699 posts
Posted 07 May 2011 - 09:25 AM
The later 'end brush' inertia starter is the lightest.
#12 booton
booton
  • 913 posts
Posted 07 May 2011 - 10:39 AM
no i mean the complete set up is the verto flywheel clutch starter everything, heavier or lighter than a pre verto
#13 benb12
benb12
  • 1,483 posts
Posted 07 May 2011 - 11:36 AM
If you're going for lightness then pre-verto is surely the way to go, you can get the flywheels much lighter than a verto. I don't know how much the whole setup weighs but 1kg off the flywheel makes a lot more difference than 1kg off the car.
#14 booton
booton
  • 913 posts
Posted 07 May 2011 - 12:43 PM
can;t afford a new atm, so thats what i was wondering is a verto flywheel and clutch compared to a pre verto flywheel backplate and clutch is heavier or lighter.
the lighter one will surely allow my engine to rev better.
#15 mini13
mini13
  • 3,810 posts
Posted 07 May 2011 - 12:49 PM
the std verto is a bit of a boat anchor, I dont know the figures but I'd say its a fair bit heavyer than a pre verto.
Its just occured, if your car is an SPI or an MPI then your stuck with the verto as it runs the injection.
