Help! My 7x13s Dont Fit!
Posted 08 May 2011 - 06:09 PM
The garage that fitted the arches says the offset is wrong. Is this correct? The arches seem to be fitted in the right place at the side indicator is in the right place and they are snug to the front bumper.
What offset should i have?
(I bought the wheels off of ebay)
Thanks in advance
Alex
Posted 08 May 2011 - 06:25 PM
As for 'they don't look right', I don't quite understand. The offset on most 13x7 wheels for minis is ET-7, but I don't see how that will have any affect on them looking central in the arches, it just adjusts how much the stick out by.
Edited by oli8925, 08 May 2011 - 06:27 PM.
Posted 08 May 2011 - 06:32 PM
Posted 08 May 2011 - 07:18 PM
Posted 08 May 2011 - 08:01 PM
Here is the only picture i have at the moment, to give you an idea (Sorry my phone wiped all the others off!)
I did have group 5 arches on before and all was fine (they did not rub on the body work as i have cut that out as per the templates) the garage fitted the sportpack arches and now when turning the wheels the outer edge of the tyre rubs the sportpack arch.
Any ideas?
(I will get better pictures tomorrow)
Edited by alextheboyowen, 08 May 2011 - 08:08 PM.
Posted 08 May 2011 - 08:09 PM
Posted 08 May 2011 - 08:11 PM
Posted 08 May 2011 - 08:18 PM
If you're wheels look like they're too far forward in the arches you may have bent Tie Bars. They connect the hubs to the front of the subframe and will push the wheel forward if bent.
Posted 08 May 2011 - 08:55 PM
Posted 08 May 2011 - 09:04 PM
I have a similar problemI will check all this tomorrow and up some pictures. Im getting desperate as i have tickets for the L2B run and a mini that does not drive!
Posted 08 May 2011 - 09:15 PM
i think part of the problem is that sportspack arches are deigned for sports pack wheels, which are both narrower and have a different offset. standard s/p arches overhang (or bury) the s/p wheels because of this.
only last week i had to cut the metal wings back on a friends mini who had s/p arches and 7x13 starmags to prevent them from catching.
my personal opinion (and it really is only that) is that s/p arches and s/p wheels should always be fitted together, other wheels dont look right with s/p arches IMO. 7x13s look best (and fit best for that matter) with somthing like grp5s etc. as i say thats just my opinion though!
Posted 12 May 2011 - 05:42 PM
I changed the tie rods and now they fit nicely.
MOT showed up lots more issues lol (like the drive shaft cutting through my exhaust!)
Fingers crossed i will make it to the L2B run.
Posted 12 May 2011 - 06:12 PM
Posted 12 May 2011 - 06:25 PM
