someone do me a favour
kada1980
, Jan 12 2006 09:54 PM
12 replies to this topic
Posted 12 January 2006 - 09:54 PM
Eventually will be sticking a turbo lump in the mini but for now may have to settle for a 1275, could someone measure there carb box (is it the same for a turbo' car?) so i can fit one before i get the car sprayed. I know a few people use battery box's, is it just a case of fitting it in the center of the bulkhead or is it off set to the side?
Karl
Karl
Posted 12 January 2006 - 10:05 PM
Errrm, you don't have to modify the bulkhead unless you are fitting a Webber or a Turbo. There's no such thing as a 'carb box' and a Webber box is very different from a turbo box. Yes you can use a battery box as a Webber box if you like, bu the turbo box is not the same thing and will have to be a bespoke turbo box. Just 'because you fit a 1275 you don't need to modify anything.
Posted 12 January 2006 - 10:24 PM
I understand i don't need one for the 1275, but i will need some sort of box for the turbo thats the measurements i'm after, i would like to fit it now before get the car sprayed both inside and out.
Karl
Karl
Posted 12 January 2006 - 10:29 PM
yeah i think the turbo box is ina slightly different position to a webber box. Not sure exactly where though.
Look in the turbo section as there will be a few links to sites on how to do it etc.
Posted 12 January 2006 - 10:32 PM
the turbo box is where the cross member is and a bit below
the webber box is above the cross member :smartass:
Posted 12 January 2006 - 10:58 PM
Posted 12 January 2006 - 11:02 PM
And this
Posted 12 January 2006 - 11:04 PM
And youll have to mod the heater mounts to move it forward a little
Posted 13 January 2006 - 01:08 AM
Cheers Mini sprocket thats spot on, any excuse to get the welder out lol
Posted 13 January 2006 - 06:32 PM
Anyone have the dimesions for the turbo box, i don't see the point in me buying one when i have some alley, metal bender and some rivits.
Karl
Karl
Posted 13 January 2006 - 06:39 PM
Its a STRUCTURAL box that keeps the rigidity in the body shell, needs to be made of steel and welded all the way round. Are you realy that short of 30 quid to buy one ready made, all the work has been done for you, just cut and shut.
Posted 13 January 2006 - 07:28 PM
True its something to consider, i don't mind buying things but don't see the point when i could make it myself... for nothing, theres no reason why rivits can't be as strong as a weld if the right rivits are used.
Posted 13 January 2006 - 07:47 PM
Mr MOT wont see it like that
