Jacking Up Using Gearbox
13 replies to this topic
#1 Jayme 1275
Jayme 1275
  • 488 posts
Posted 09 May 2011 - 09:35 PM
Hi im wondering is the bottom of the gearbox strong enough to jack th car up on I've seen a few pics in mini magazine and mini world of this and I'm just wondering is it safe?
#2 mini13
mini13
  • 3,811 posts
Posted 09 May 2011 - 09:36 PM
its not nice...
#3 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 09 May 2011 - 09:37 PM
not the best idea, especially if you mounts have seen better days stick to the subframe where all the suspension and front wheels join on.
#4 samsfern
samsfern
  • 5,243 posts
its not so much the gearbox being strong enough, its your engine mounts, theyll be put under a huge amount of strain, jack it up under the subby, i normally go on the tiebar bracket.
#5 MRA
MRA
  • 7,607 posts
Posted 09 May 2011 - 09:39 PM
Simply NOT safe !!!
You are relying on something not breaking, which is never a good idea :withstupid:
#6 Big_Adam
Big_Adam
  • 7,435 posts
Posted 09 May 2011 - 09:40 PM
You don't jack the gearbox bar for a few specific times. Like jacking the engine up to get the last bolts out of the flywheel cover.
Even then you stuck a big ol' bit of wood under it.
But you shouldn't jack the box normally, as it might crack.
#7 Jayme 1275
Jayme 1275
  • 488 posts
Posted 09 May 2011 - 09:43 PM
I see some one mentioned jacking it up by the subframe which part you use the bit infrint of the gearbox
#8 mini13
mini13
  • 3,811 posts
Posted 09 May 2011 - 09:45 PM
no, to the left and right of the enine where the bottom suspension arm mounts.
#9 Cooperman
  • 23,326 posts
Posted 09 May 2011 - 09:55 PM
"Not many people know this", but in 1959 when the Mini was introduced, there was a special piece of wood with a BMC part number which went under the sump for jacking. It was soon deleted due to the engine mountings failing and resulting in warranty claims.
#10 connor_cooper
connor_cooper
  • 164 posts
  • Local Club: no
Posted 10 May 2011 - 04:30 PM
Go under the subframes for jacking the car, but if you want to raise the engine a little from the bottom when you're taking it out i would have thought the gearbox would be ok, just make sure you use a hefty piece of wood!
#11 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 10 May 2011 - 04:45 PM
I wonder how much those bits of wood are worth now to mk1 concours car owners!
#12 MRA
MRA
  • 7,607 posts
Posted 10 May 2011 - 06:35 PM
Ive got loads of bits of genuine old wood... maybe they are worth something :)
But like all things "special" they probably would be worth a fair amount...
#13 Carlos W
Carlos W
  • 10,114 posts
Posted 10 May 2011 - 06:45 PM
There's a big difference between jacking the engine up, (ie supporting the weight of just the engine on a jack) and hanging the whole car from the engine mounts!
You certainly wouldn't get me under a car which was jacked up on the engine!
#14 charie t
charie t
  • 3,153 posts
Posted 10 May 2011 - 10:17 PM
Do not jack it under the engine. As said you risk cracking the sump/gearbox casing and/or destroying the engine mounts
Front or rear, jack it under the widest flat part of the subframe. Narrow headed jacks such as the draper model, can put excess pressure oin one area and bend the subframe so a decent peice of wood is adviseable to spread the load. Also protects your nicely painted subframes :)
Edited by charie t, 10 May 2011 - 10:18 PM.
