Wont start, is starter wired properly??
miniman207
, Jan 12 2006 11:13 PM
14 replies to this topic
Posted 12 January 2006 - 11:13 PM
Evening folks me again!!!!
Right have finally sorted out all other problems with car and was finally ready to giv her a go at starting, altho all i got was a click then some smoke!!!!
i dont know if its the wiring i have done wrong or if the starter is knackered, wiring is.
white to + on coil.
white/black comes from dizzy then splits in 2, 1 goes to - on coil other back to white/black from wiring loom.
white/yellow from dizzy to + on coil.
Another wire that someone has put in from + on coil to the starter solenoid
It is electronic ignition by the way on a 1275 engine.
If this all seems ok then does anyone know anything else it could be?
Gaz
white to + on coil.
Gaz
Posted 13 January 2006 - 03:49 PM
White and yellow from dizzy?
White/yellow is the starting ballast bypass on ballasted ignition cars. You shouldn't have a white/yellow on a car fitted with a white wire to the coil, and you shouldn't have any wires running from the coil + to the dizzy at all except perhaps with certain aftermarket ignitions that have ignored the wiring colour standard.
What electronic ignition is it, and what's this extra wire about? I suspect I know and it could well mean that you have blown up your module, hence the smoke.
Posted 13 January 2006 - 03:55 PM
im not sure which electronic ignition it has im not at home at the min so cant look,
could you give me an idea of how it should be wired then please because there are wires that have been added so i am at a complete loss. i found a wiring diagram which i followed except i had completely different colours and hence it didnt work!!!!
Gaz
Gaz
Posted 13 January 2006 - 04:01 PM
Not completely without knowing which electronic ignition it is. If it's the type which fit completely inside the distributor then you pretty much wire it the same as standard ignition but then take an extra feed to the module to power it. If it's one of the older systems then there will be a seperate module somewhere which needs wiring and then a fairly large loom to run from that to the distributor.
Also you need to identify the type of ignition system you have as it sounds like you've got a butchered ballasted system.
Posted 13 January 2006 - 04:04 PM
give me 20 mins ill shoot home hav a look then let u know ill take a few piccys aswell
Posted 13 January 2006 - 05:06 PM
here are some pics hope they come out ok!!!
the electronic ignition is LUCAS with a LUCAS coil
Posted 13 January 2006 - 05:07 PM
another
another
Posted 13 January 2006 - 05:08 PM
another
another
Posted 13 January 2006 - 05:09 PM
another
Posted 13 January 2006 - 06:05 PM
Hi just had a lok at ur pics. I have an MG metro 1275 engine in my mini and the distributer looks the same as urs. My ignition moduel is wired to the coil. One wire to + and one the the - The other conections to the coil are a power feed and a connection the the rev counter. Hope that helps. Cant really tell where your wires go looks like the either both go to the same side of the coil or only one of them is connected to the coil and the other goes somewhere else.
Posted 13 January 2006 - 06:12 PM
At the min i have
White feed to the coil
a cable that has been added from the solenoid to + on the coil
black/white from dizzy to - on coil and also splits back to loom (rev counter)
white/yellow from dizzy to - on the coil
This sounds the same as you have on yours!!!!!!
Posted 13 January 2006 - 07:16 PM
not quite
the ones going to the dizzy. Mine one goes to the negative and one to the positive on the coil
Posted 13 January 2006 - 09:40 PM
got it sorted now cheers, now i have just gotta return the fuel pump i bought and get the correct 1 and i should be al systems go
Cheers for all your help
Gaz
Gaz
