Weber 28/36 On A 1275?
Posted 10 May 2011 - 05:45 PM
cheers
Posted 10 May 2011 - 06:01 PM
Fitted one to my MG Metro, easily out performed the HIF44. Then later on used it on my 1380, excellent carb despite what's about to follow from all those that have never used one.
I'm with DILLIGAF on this, go for the 28/36 I have one on my 998 and it is better than the SU/HIF configurations I have tried.
Posted 10 May 2011 - 06:13 PM
Posted 10 May 2011 - 06:16 PM
any pics/videos?!
Posted 10 May 2011 - 07:39 PM
I have one sat in the garage, if its anywhere close I might give it a go.
Posted 10 May 2011 - 07:59 PM
Posted 10 May 2011 - 09:11 PM
Posted 10 May 2011 - 10:11 PM
Posted 10 May 2011 - 10:32 PM
We have someone in cape town that casts new aluminum manifolds so went for it. If you can get a good manifold I say why not try it out for yourself.
cheers
Posted 10 May 2011 - 11:19 PM
Posted 11 May 2011 - 07:41 AM
My primary choke doesn't close properly after opened, seems like its missing a return spring.
Posted 11 May 2011 - 05:56 PM
Edited by shed, 11 May 2011 - 05:56 PM.
Posted 11 May 2011 - 07:44 PM
Just a quick note, Bluecray's picture has the carb on the wrong way around. Having the float chamber behind the the carb, can cause fuel starvation problems.
The float chamber needs to be at the front.
Well it seems to run quite happily like that, and if was turned around the throttle cable would be difficult to configure, it would need to be a lot longer and have to come ALL the way round to the other side. As it is, there's a more direct throttle connection.
I'm leaving it as it is.
Posted 14 May 2011 - 12:37 AM
However on my rebuild, 998 with 12G940 head a quick test show it now sits higher...
So i am looking to chop the filter down so it is thin enough to clear.
Posted 14 May 2011 - 04:36 PM
