Gearbox Ratio - One For Guessworks
Posted 10 May 2011 - 09:10 PM
Now I know that my speedo is now wrong but is my rev counter now wrong also??
I have been looking at the calculator on Guessworks website and the revs seem to fit the mph at low revs but the higher I go in rev range the bigger the difference between what my speed is and what the speedo show. Is this correct?
Sorry if this doesnt make much sense, but it does in my head.
Posted 10 May 2011 - 09:12 PM
the speedo takes it's drive from the gearbox, so if you have had a new final drive fitted, chances are you'll have to change the speedo drive to match.
Posted 10 May 2011 - 09:16 PM
Posted 10 May 2011 - 09:35 PM
Posted 10 May 2011 - 09:40 PM
Posted 10 May 2011 - 09:42 PM
The speedo drive is measured from the gearbox just before the nfinal drive, so the percentage inaccuracy will be the same in each gear. The faster you go in terms of road speed, not in terms of engine revs, the greater will be the error. Going from 3.44 to 3.1 FD ratrio, your speedo will under-read your true speed.
If you take the indicated speed, divide it by 3.1 and multiply the result by 3.44, you will have the true corrected speed, subject to the original speedo error of course. In percentage terms it's approximately 11% under-reading, so add,say, 10% for a quick indication of actual speed.
Posted 11 May 2011 - 01:04 AM
I also need someone to follow me and keep tabs on my speed.
oooooh the joys of Mini ownership lol
Posted 11 May 2011 - 05:57 AM
Posted 11 May 2011 - 06:52 AM
With a 3.105 final drive the same car would do 18.25mph/1000rpm = 55mph @ 3000rpm
Posted 11 May 2011 - 07:55 AM
Posted 11 May 2011 - 09:26 AM
And you tacho (rev counter) could quite easily be 1000 rpm out.
Posted 11 May 2011 - 09:51 AM
I know in theory a sat nav can't be wrong (apart from not knowing when you are going on an incline/decline which would affect the reading) but it is about 2-3 mph out at 50mph in my truck. Best way- follow a lorry with a friend driving!
Posted 11 May 2011 - 10:03 AM
By far the easiest resolution must be to have the speedo drive changed to the correct one for the final drive ratio, or to contsantly run a GPS
Posted 11 May 2011 - 10:19 AM
I have 10" wheels, 3.44 diff, 1280 turns per mile speedo and correct speedo gears in the gearbox. Working backwards from the figure of 1280 turns per mile, this gives a figure of 16.53 mph/1000rpm and also an effective radius of the wheel of 243mm.
A rolling road session indicated I had nothing like 16.53mph/1000rpm. The reality is that the measured effective radius of the front wheel when laden is more like 230mm. (You have to roll the car a bit just before measuring as it settles down even further when left to stand).
The result is that I actually have 15.65 mph/1000 rpm and so the mileometer reads 5.6% high. I had already tweaked the speedo needle on the bench so it read correctly at 70mph (assuming 1280 turns per mile), so that also reads 5.6% high at 70mph when in the car.
In fact I rely on my rev counter for speed (using the 15.65 mph/1000rpm figure) as it has been calibrated at 3000rpm and 6000rpm using mains frequency.
Posted 11 May 2011 - 11:36 AM
