Gearbox Ratio - One For Guessworks
17 replies to this topic
#16 MRA
MRA
  • 7,607 posts
Posted 11 May 2011 - 11:41 AM
Interestingly a rolling road will distort the tyres, therefore they are only as accurate as th ethe dimension used... ie the tyre radius to road and the tyre radius to rolling road....
There is no such thing as perfect..... everything has a tolerance therefore your tacho will not be exact, however the tolerance is somewhat smaller to that used by car manufacturers.....
Your speedo is not connected tot he gears it is directly connected to the output sahft to the diff and is directly proprtional to the speed of the wheels going around...
Another point, as your tyres pick up speed and the wind goes under or over your car the rolling radius can change quite dramatically, look at the rear tyres on a dragster "rail" car as they spin they grow in diameter.
Most tyre manudfacturers quote wheel revs with a speed, ie wrpm at 30mph = 1080 etc....
Edited by mra-minis.co.uk, 11 May 2011 - 11:43 AM.
#17 Msmith3327
Msmith3327
  • 220 posts
  • Local Club: Torbay Mini Club
Posted 11 May 2011 - 11:47 AM
This is getting really confusing.
How would i figure out which is the correct speedo drive for me?
#18 rwerry
rwerry
  • 386 posts
Posted 11 May 2011 - 09:20 PM
>_<
Guessworks' excellent website will calculate this for you. Just fill in all the (other) info.
http://www.guess-wor.../Tech/ratio.htm
