Cleco Skin Pins
3 replies to this topic
#1 BusheyTrader
BusheyTrader
  • 481 posts
  • Local Club: Nope
Posted 14 May 2011 - 10:14 PM
Hi,
I'm looking at buying a set of these.........
Which size works best for the type of work needed on a Mini? I was thinking 1/8th" 3.2mm since it leaves a relatively small hole to weld up.
Thanks in advance
Adam
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,089 posts
  • Name: Neil
Posted 15 May 2011 - 03:41 PM
Hi,
Thanks in advance
Adam
Personally i would use 5/32 nds as they give a bit more clamping force plus the holes are still easy to fill with weld. I use a mixture of 1/8th and 5/32 skin pins and Cleco pins. The skin pins clamp better than cleco but because they have a nylon pad they tend to melt if you weld close to them.
#3 BusheyTrader
BusheyTrader
  • 481 posts
  • Local Club: Nope
Posted 15 May 2011 - 06:18 PM
Thanks, I've ordered some of the non melting variety to try them out......
Adam
#4 BusheyTrader
BusheyTrader
  • 481 posts
  • Local Club: Nope
Posted 28 May 2011 - 04:51 PM
and they work fine.
Really good for places where welding clamps won't reach. Just don't expect them to pull wayward panels together like normal clamps.
