Does my diff need replacing?
Posted 13 January 2006 - 08:47 PM
I think the Diff has gone, it's an N reg Rover Cooper SPI, When driving I lost all power to the wheels accompanied by a nice grinding noise. The speedo was still reading above zero so drive is getting to at least some of the gearbox. The drive shafts appear to be OK and look to be located correctly in the CV joints.
I suspect it is the diff that has gone but is there anything else that I might have overlooked?
If it is the Diff, is there anything I should consider when replacing it?
Anything I particularly need to look out for or check?
Is it worth changing the whole gearbox?
Any help is greatly appreciated
Posted 13 January 2006 - 09:03 PM
Posted 13 January 2006 - 09:09 PM
Looks like I will be removing the engine to see how bad it looks in the box.
Posted 13 January 2006 - 09:54 PM
You could drop a metro engine in for the time being. That way you could take your time on the engine.I didn't run the car for long, just long enough to diagnose where the fault might be. It was enough to convince the AA Bloke to not even look at the car when he came to tow it. I don't really want to be rebuilding the engine at the moment because I might be going down the turbo route soon anyway.
Posted 13 January 2006 - 09:57 PM
The metro engine will probably form the starting point for the turbo engine
Posted 13 January 2006 - 09:59 PM
Posted 13 January 2006 - 10:01 PM
Cut along story short my flywheel welded to the crank which made getting to the gearbox difficult
Posted 13 January 2006 - 10:03 PM
but as on Minifinity ( sorry guys been moonlighting :cheese: ) check the diff splines, etc.
SHoot it's just dawned on me..
Check one the of the pots, has just not popped off ( if the ring clip fails the this is a high probability ) you turn round a corner, and the drive shaft is pulled off. all of a sudden no drive and a grind...
Edited by GuessWorks, 13 January 2006 - 10:04 PM.
Posted 13 January 2006 - 10:12 PM
I have a metro box attached to another engine which I know is OK, no crunching of gears, no dropping out of second or anything so I can use that (I drove it round for over a year with no problems at all). Ideally I would like to keep the final drive ratio of the cooper, 3.2 I believe? I am guessing this may be difficult if the diff is in fact damaged? The metro is 3.44. What needs swapping (or getting replacements) to keep the 3.2 ratio?
Posted 13 January 2006 - 10:50 PM
Edited by Mini Sprocket, 13 January 2006 - 10:53 PM.
Posted 13 January 2006 - 11:07 PM
advice on here so far is correct just remember its an spi so u cant just drop a metro engine in as no crank sensor
dave
Posted 14 January 2006 - 09:52 AM
If I did leave the 3.44 final drive what speedo drive bits will I need to use to keep a correct (as far as I can) reading?
Posted 14 January 2006 - 11:23 AM
Posted 14 January 2006 - 01:25 PM
Posted 14 January 2006 - 05:03 PM
