hello me again!!
right i sorted the wiring out 4 the lucas electronic ignition i have, there is a feed getting to the coil and comming out of the coil to the dizzy but i am not getting a spark from any of the leads.
The leads are all fine and the dizzy cap is slightly warn but not enough to cause any problems. the rotar arm looks fine aswell.
any ideas what it could be???????
Cheers Gaz
No spark at the plugs
miniman207
, Jan 14 2006 02:25 PM
2 replies to this topic
Posted 14 January 2006 - 02:25 PM
Posted 14 January 2006 - 03:12 PM
by the way its in a garage so cant be anything to do with being wet!!!
Posted 14 January 2006 - 03:31 PM
Are none of the plugs getting a spark, or just one? If its none then I'd suggest changing your dizzy cap, points and/or rotor arm. Also, are you sure its not the lead from coil to the dizzy?
