2nd Gear Crunch
3 replies to this topic
#1 Minisport7
Minisport7
  • 73 posts
Posted 19 May 2011 - 03:30 PM
[b]Model: Cooper Sport
[b]Year: 2000
Hi,
My mini often crunches in 2nd gear, especially in the high RPM ranges. My friends' older mini does the same, which tells me its a mini thing, just wanted to double check it was and whether or not it could be resolved somehow.
All input appreciated.
#2 starletman
starletman
  • 249 posts
Posted 19 May 2011 - 03:44 PM
[b]Year: 2000
Hi,
I believe its the baulk rings in the gearbox,try doubling the clutch when changing down and it will work a little better.
#3 danielevison93
danielevison93
  • 222 posts
Posted 19 May 2011 - 03:48 PM
[b]Year: 2000
Hi,
mine does that sometimes if you drop into second a bit too quick, normally if i take it slower, it doesnt do it as much :thumbsup:
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 May 2011 - 06:05 AM
Yes it can be fixed, but does mean the engine needs to come out of the car for the gearbox to be reconditioned...
The baulkrings are wear component of the gearbox, slowing down and speeding up the gears to enable the normally smooth crunch free gear change. The crunch is the dog teeth of the gear and synchro hub coming into contact, and if the problem is not resolved, will eventually damage both of these parts beyond reuse...
