ive got a quick rack waiting to go on, but i cant seem to get my old on off, ive took the bolt out at the bottom of the steering shaft? and the 4 bolts that hold the brackets in, is there anything else i need to do because it aint movin??
steering rack
wobblybob
, Jan 14 2006 09:37 PM
10 replies to this topic
Posted 14 January 2006 - 09:37 PM
Posted 14 January 2006 - 09:56 PM
You removed the U-bolts?
Posted 14 January 2006 - 10:28 PM
think so, r there 2 of them and the bolts go in the inside the car?
I think you have to drop the back of the subframe to allow you room to pull it out
<karl>
<karl>
Posted 14 January 2006 - 10:31 PM
subbys allready off
Posted 14 January 2006 - 10:32 PM
have i got all the bolts? shall i just pull really hard?
Posted 14 January 2006 - 10:34 PM
Think so, might just be rust holding it on?
Posted 14 January 2006 - 10:39 PM
prob i'll give it a go in the morning
Posted 14 January 2006 - 11:15 PM
cosh it with a hammer from the inside. that what i did. then found out they needed wigglin off to one side.
Posted 14 January 2006 - 11:50 PM
If you've completely removed the 2 U-bolts then there isn't holdiing it on, I take it you've taken the steering column off, and the track rod ends are disconnected?
Posted 14 January 2006 - 11:59 PM
stick a wide screwdriver in the clamp where you took the bolt out of on the steering column shaft. that oughtta free it up
