Wood And Pickett Interface For Central Locking
Posted 16 May 2011 - 05:38 PM
Posted 16 May 2011 - 05:54 PM
Posted 16 May 2011 - 06:12 PM
I've got the £20 ebay kit (same thing) - but I have never had any problems. Nor have I heard of anyone having this problem. Are you shorting out anywhere and where have you taken you live from?
the central locking on the key works fine, the interface [which im having the problem with] does not have a live as such- its wired into the central locking harness , as per instruction . I've checked for shorts and exhausted everything. The black wire on the interface goes to the black wire on the central locking harness, then 2 wires to each of the locking motors. If you mean the power for the central locking unit-- Gosh I cant remember where I took that from it was years ago but IT works fine. IM thinking it has something to do with the wires that go to alarm module behind the dash as the fuse blows for this when I have pressed button on keypad- 5 fuses so far. All dosconnected now - given up on it!
Thanks for your input anyway but seems there is no way forward on this one!
Posted 16 May 2011 - 06:14 PM
But the interface should have 5 wires - 1 earth, 2 to the alarm ECU and 2 to the c/l harness.
Posted 16 May 2011 - 06:31 PM
On my interface the black wire is the earth.
yep thats right, all accounted for
Posted 16 May 2011 - 07:22 PM
Posted 16 May 2011 - 08:34 PM
Are you sure they are all into right place? What colours are the wires?
yes defo, ive checked and double checked, this is in fact the second time I tried fitting as the first time I tried couple of weeks back I had to call out Rac and with his help eventually found the fuse which had blown so, this time [after making sure I had the correct wp central locking kit with the guy in brighton yesterday as I thought this maybe why fuse was blowing] I tried again but alas same problem , just blows the 20amp fuse. I can post the instructions up
Posted 16 May 2011 - 08:35 PM
Posted 19 May 2011 - 10:18 PM
maybe the kit itself is faulty ..
Mark
Posted 20 May 2011 - 08:07 AM
You triple checked the wiring?
Mike
Posted 20 May 2011 - 08:34 AM
Posted 20 May 2011 - 08:37 AM
I'd take it all out and start again.
Posted 20 May 2011 - 08:55 AM
Sounds like you have extra juice in the loom for it to blow fuses.
Mike
hehhee, I had 2 attempts at fitting the kit and thought I was at fault somehow when the fuse went and had to call out RAC- he and me took a while to find the damn fuse! I went over and over checking connections. The wp kit is about ten years old, different type maybe.. dunno
Posted 20 May 2011 - 09:11 AM
It's easy to get 11 and 13 in the wrong pins.
mmm did that and started again .. same scenario- just blows fuse, maybe ill try changing the said wires around as instructions might be wrong.
It does mention a white wire in the instructions that isnt used on the interface- there is no white wire on the interface I have
Posted 20 May 2011 - 09:41 AM
