hello people,
well El Gordo (my mini) is running nicly but seems to still be using alot of fuel. i did write it down so i'll have to post that tommrow but anyway, the float chamber on a carb...........should it wiggle. i mean mine moves a fair bit which i think is bad. should it move and if not what could have gone wrong to make it move.
thanks people!
Errrr,,,,,should that wobble??
Big_Adam
, Jan 14 2006 11:18 PM
5 replies to this topic
Posted 14 January 2006 - 11:18 PM
Posted 14 January 2006 - 11:30 PM
i believe they are ment to move but couldn't tell you how much by tho??
Posted 14 January 2006 - 11:57 PM
You definitely sure its a wobble? A wobble is officially difined as a deviance of +/- 2 degrees. A wiggle is +/- 4 degrees and a rock is upto +/- 10 degrees! Found that out today!
Posted 15 January 2006 - 08:43 AM
It should move a bit if you try to force it, but not on its own. It's rubber isolated from the carb body to stop it vibrating.
Posted 15 January 2006 - 01:18 PM
none of mine are? They're all just bolted directly to the body of the carb, with only a small metal washer between them - and that's only to dictate the angle of the float bowlIt's rubber isolated from the carb body to stop it vibrating.
Behind the cams where the throttle+choke cables attatch, should be a 1/2" bolt. Try tightening that up to see if that solves it
Posted 15 January 2006 - 06:31 PM
It should not wobble or wiggle - tighten it ! But Minis DO use lots of fuel relative to modern cars.
