Enough Room For Oil Change Without Ramps/jacks/stands?
7 replies to this topic
#1 the_r_sole
the_r_sole
  • 831 posts
Posted 20 May 2011 - 05:18 PM
oil change coming up this weekend, is there enough room to get in at the sump plug without having to lift the car at all, i know nothing is that easy to access under the bonnet, but am i hoping for too much here?!
#2 R1minimagic
R1minimagic
  • 4,660 posts
Posted 20 May 2011 - 05:21 PM
Yeh if you use a cat litter tray!
#3 matt615
matt615
  • 923 posts
Posted 20 May 2011 - 05:23 PM
Yes it's perfectly possible to change the oil on a Mini without jacking it up. The sump plug is near the front of the Mini, so it's quite easy to lie on the ground, stick your arms underneath and undo it.
#4 andy159
andy159
    Speedy fingers.
  • 837 posts
Posted 20 May 2011 - 05:31 PM
i find that it you cut an old oil containers side off you can slide it underneath and do it that way
#5 MRA
MRA
  • 7,607 posts
Posted 20 May 2011 - 05:34 PM
If your mini is especially low use a kerb edge or similar to get the required height..... don't forget to put the left side on the kerb so as to drain the oil easier and better ;)
#6 Big_Adam
Big_Adam
  • 7,435 posts
Posted 20 May 2011 - 05:36 PM
Go to el chepo shop, buy a large plastic container.
Cut 85% of it, job done. Best oil tray I ever had. No jacks, stands, just slide it under and undo the sump plug.
#7 the_r_sole
the_r_sole
  • 831 posts
Posted 20 May 2011 - 05:38 PM
i've actually got some big plastic bakers trays which sit under the engine no probs, usually have one under there when i'm doing anything as something is bound to fall or slip out your hands, much easier to slide a big tray out than try to scratch around the floor ;)
(just need to remember not to pick up the one with a crack in it like i did when i was changing the coolant wondering why so little was coming out!!)
#8 evansisgreat
evansisgreat
  • 1,103 posts
  • Local Club: Not yet
Posted 20 May 2011 - 06:37 PM
The first time I changed my oil I thought I was nice and prepared and ralised I forgot to get a tray. I found a container that I thought was big enough.... you can guess the rest.
I now have a proper oil drain tray haha!
