Switching To 13" Wheels
Posted 23 May 2011 - 03:43 PM
If I were to replace my 5.5x12 wheels with 7x13 wheels,
what do I need to do? I am aware that the wheel arches need to be cut,
but what else needs to happen? better wheel bearings?
thanks!
Posted 23 May 2011 - 04:01 PM
It's just personal choice, as are so many things Mini.
Posted 23 May 2011 - 04:04 PM
some very useful information there which I will certainly think about before making my decision
thanks!
Posted 23 May 2011 - 04:11 PM
thanks for your response,
some very useful information there which I will certainly think about before making my decision![]()
thanks!
Yes, I'm a bit biased as I think the 13" look horrible.My good friend in the village here has a Sportpack which had 13" wheels, but after he drove one of mine on 12" he changed his to 5" x 12" Minilites with the earlier type arches. In fact cutting the original wings for the 13" had caused so much rust we had to fit new wings.
I think 13" might be OK for racing where ultra-wide sticky slick tyres can be used in the dry, but for the road those very wide tyres are poor in the wet due to insufficient contact pressure and in snow or ice they are worse than useless.
Posted 23 May 2011 - 04:56 PM
Right lets put some old wifes tales straight.... if they are NOT a performance enhancer howcome they wear out wheel bearings ???
13" wheels and tyres do NOT cause any more rust to your bodywork that is down to shoddy workmanship.....
Agreed they are less useful in snow or ice, however we don't get too much of either really do we .. ?
Edited by mra-minis.co.uk, 23 May 2011 - 04:57 PM.
Posted 23 May 2011 - 05:25 PM
13" wheels and tyres out brake 10" anyday, they also give you a better footprint for better traction off the line....
They wear out wheel bearings because of the added cantilever effect of moving the tyre centre-line outboard. If the approximate weight on each front wheel is 400 lb and the offset is a further 2" over, say, a 5" wide rim, that is an added basic torque to be resolved by each front wheel bearing of around 7.5 lb.ft. When cornering and over any bumps, that figure is multiplied. They also screw up the basic as-designed steering geometry.
They may give better traction off the line on a dry day when doing a 'drag-type' start. But only in the dry.
They will be fine with sticky slick racing tyres on a dry track as that sort of tyre is designed to work at lower contact pressures when the rubber is warm. But you can't use a slick on the roads. On a racing car the added wheel bearing and suspension wear issues don't matter anyway.
A 13" won't outbrake a 10" 'anyday'. It might do so in the dry on a very smooth road. It won't outbrake a 10" in the wet, on a bumpy surface, on ice, in the snow or on any slippy or muddy surface.
Yes, the rust is down to shoddy workmanship or, in the case of the Sportpack, very poor production processes.
Posted 23 May 2011 - 05:53 PM
The load on the bearing is due to lots of effects, static and dynamic, however by far the greatest is due to dynamic effects, the difference between a 10" & a 13" tyre rolling radius is not a great deal, thus the torque effect whilst cornering is similar if the grip is the same, so if the grip is so superior on a 10" tyre why do 13" tyres wear out wheel bearings so readily ???
I have been using 13" tyres on my Mini since the early 80's and wheel bearings when fitted correctly last for years, my last set have been on my Mini with 195/45-13" for over 25,000 miles wiyhout any issues..
Granted skinnier tyres are better on ice, snow, mud..... but to quote the OP
Quote
Hi,
thanks!
Quote
The OP wants to know what to do to change to 13" wheels and tyres not your personal opinions on them....
Yes you can get better wheel bearings, as the OP's car could quite easily have ball roller bearings in the front and rear hubs, and changing to taper roller bearings will be an upgrade
Posted 23 May 2011 - 06:02 PM
... I much prefer the 13" and can't say i've noticed much difference in the cars performance they just look so much nicer! other than the fact the car feels more sturdy
Posted 23 May 2011 - 06:03 PM
just logged back in and I've been pleasantly surprised to see all this discussion,
very useful stuff!
thanks guys!
Posted 23 May 2011 - 06:14 PM
The grip is not superior on a 165 tyre over a 175 (or wider) so long as overall average grip is considered. However, there are times when the very wide tyre will lose out, and those have been identified - in the wet, on slippy or slightly broken/bumpy surfaces, on ice, in snow. The trouble is that it's at those times that the loss of grip can be critical, especially in the wet.
Guest_minidizzy_*
Posted 23 May 2011 - 11:55 PM
Regardless of whether the OP was looking for an opinion there are some on an open forum who welcome your very valuable opinion. I have always understood that 12" wheels are preferable to 13", visually and performance-wise, which is why I bought a non-sportspack Rover Cooper. I recently bought, but have yet to fit, four Yoko A539 165/60/12 tyres to replace my ageing but not yet worn out Pirelli Cinturato 145/70/12 tyres on the grounds that the latter are well past there use-by date. The wheels will remain the original 4.5" and the tyres are asymmetrical to deal with the increased width. Was this a bad idea and likely to increase wear with the cantilever effect on the bearings as well as compromising the design geometry and should I have gone for Falken 145/70/12, which are the only current equivalents to the Cinturatos? I am not clear whether it is the centre line of the wheels or the tyres which is crucial.
Posted 24 May 2011 - 12:09 AM
You'll love the 165/60 A539 as it's a superb tyre and on the original Minilite 4.5" wheel you will probably have the best wheel/tyre set up for a car with 8.4" discs. They will give much better road-holding than the Pirelli.
My buddy in our village changed from 13" to 12", but he has the 5" wide with Falken 165/60x12 and loves it. I've driven it with both 13's and 12's and know which I prefer, especially in the wet.
When i had the A539's on a hot 998 a year or so back I found that a pressure of about 32 psi was excellent, but experiment from about 28 to 34 to see what bsuits your driving style best.
Guest_minidizzy_*
Posted 24 May 2011 - 12:13 AM
Posted 24 May 2011 - 07:23 AM
In most cases there will be no differance between any size trye (available for the mini) regarding grip in the wet, only when there is lots of standing water will a narrower section tyre have an advantage. And who cares which one is better in the snow?
Again the wheel bearing issue may have some basis on 7" wide wheels , but with 5.5s and 6s the wheel position is pretty much the same as any other 12 or 10" wheel.
