You can have a look here : Visit My Website
But there is one thing that is annoying my "I want to optimize everything" compulsion:
The mecanical fan and water pump.
I know they are "vintage", but no modern car would even think of going back to these setups for at least 2 reasons:
- noise
- power efficiency
As for the noise, I recently changed my stock Spi plastic fan to a "6 blade export" (I leave in Portugal), and the result is... a lot of noise!
The cooling improvement compare to the stock one seems small: I would expect better with a supposedly "enhanced 2 core aluminum rad", my secondary fan still cuts in frequently when I'm driving in town, just like before.
But let's go back to our topic:
I've read some post claiming "why bother? Your mini came with a mechanical fan / water pump leave it that way".
Following the same logic, my Mini would still run 63bhp, instead of 94 (and counting), be black, have a nice full plastic interior...
We want the best for our car (even if with some financial constraints) !!!
So let's recap:
A powerful water pump, available at Merlin Motorsport Here drows a maximum of 7.5A from your electric system.
A 10'' electric fan, available everywhere, including at Merlin Motorsport Here drows also a maximum of 7.5A from your electric system.
You may want to leave the secondary electric fan (my car is originally an Spi), adding another 7.5A.
That's a total of 22.5A, resulting in 270W (22.5Ax12V) of power, which is about 0,36 BHP. That's a maximum value, only achievable when the car is really running hot in traffic with all 3 electric appliances pumping together.
The alternator from the Spi is rated at 70A so there should be no problem (that's about the same draw as a set of 4 spot lamps anyway).
I suspect the removal of the mechanical fan and water pump will add more than 0,36BHP to the car, especially at high RPM.
The additional benefit will be the improved colling at engine cut, when the fan and pump are able to keep cooling the engine for a few minutes.
Now I need some help on a few points:
1- will 2 electric fans (push/pull) be enough on a side mounted radiator, or do I need to set a front mounted rad (I can even imagine setting a kind of "front mounted secondary water radiator").
2- if a front mounted radiator is necessary, is there some model that you would recommend (small, with entry/exit on the side...)
3- will I need to relocate my alternator and if so is it possible to do it while keeping the stock Spi one?
Thanks for your answer and comments
Diogo
Edited by diogoteix, 23 May 2011 - 04:37 PM.
