Fault Code Identification 4xv 1999 R1 Flicks From0 To 13.6k
3 replies to this topic
#1 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 23 May 2011 - 09:35 PM
I've searched everywhere and can't find an answer. My rev counter is giving out a fault code. It flicks from 0 to 13600rpm. I have found out what the codes listed below mean, but I cn't find what my code relates to???
3,000 revs = Throttle Position Sensor
4,000 revs = Speed Sensor
7,000 revs = EXUP
8,000 revs = Fuel Sensor/Sender
9,000 revs = Tip over sensor
Edited by Alburglar, 24 May 2011 - 03:01 PM.
#2 R1minimagic
R1minimagic
  • 4,660 posts
Posted 23 May 2011 - 09:52 PM
Did you take the exup off?
#3 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 24 May 2011 - 03:00 PM
Yes but Exup code is 7k
#4 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 24 May 2011 - 09:48 PM
...it was the exup :thumbsup:
I figured I'd start working through all the 4 possible issues that give out fault codes just to make sure and the exup was the first one I tried. I have a quick fix though. A 10k resistor between the black/red wire and the white/red wire that come out of the ECU. sorted
