Posted 25 May 2011 - 12:44 PM
Which pump is better depends on several things, namely how you are going to use your car. In almost all instances, the road pump will be fine and it will be your least expensive option. I cannot speculate on the suitability of these pumps with your engine build specs. Others who have made similar changes will have to offer their comments. However, for most street cars either of these pumps will supply sufficient fuel. Remember that the pump does not FORCE fuel into the engine, only into the float bowl. Once fuel is in the float bowl the fuel is sucked into the carb by vacuum. Therefore, the pump only needs to deliver fuel fast enough to the engine to maintain the proper level inside the float bowl.
Road Pump (Facet solid state brick)
Low-cost, 2-3 PSI. The lower pressure is correct for the SU carb and therefore... no regulator (no Filter King) is required. However, you should put a disposable filter between the pump and carb.
Interrupter Pump (Facet red top)
Higher-cost, 4.5 PSI. The higher pressure may cause your SU carb to flood. Therefore, you WILL need a regulator to lower the pressure to about 3 PSI. You have the Holley regulator. If it is not damaged by the SPI pump it is not hard to adjust and will work well with the interrupter pump. As above, you will want a disposable filter between the pump and carb. HOWEVER, if the Holley regulator is damaged, or if you simply want to use a Filter King, the Filter King will function as both a regulator and a filter (meaning you would no longer have to use the Holley regulator). The Filter King would go between the pump and carb.
However, understand that you do not "have" to buy the Filter King. That is up to you. Your Holley regulator and an inline disposable filter will achieve the same result.
