Race Bucket Seats Rear Seat Access
13 replies to this topic
#1 smtaylor3
smtaylor3
  • 160 posts
Posted 25 May 2011 - 06:24 PM
hi am thinking of fitting race bucket seats but am wondering whats the access is like to the back seat when the seats are tilted forward
thanks steve
#2 Ryan Hunt
Ryan Hunt
  • 240 posts
Posted 25 May 2011 - 06:26 PM
Can be tricky at best if they arent reclining ones, but you saying race I take it you mean fixed back.. you can make a subframe for them to tilt on, but its not the easiest of tasks (getting in and out) either way
#3 crazycoleman118
crazycoleman118
  • 836 posts
Posted 25 May 2011 - 06:42 PM
dependant on the seat, ive got corberau clubmans. and its almost impossible. if you have a bit of a stomach or had dignity you wouldnt be able to get in.
thats on sliders/tilting frames too
#4 shed
shed
  • 594 posts
Posted 25 May 2011 - 07:20 PM
ive got reclining corbeaus (or however yer spell it) and they arnt too bad to get behind if you slide the chairs forward but you can only tilt so far because the headrest hits the roof but certainly easier than standard front seats
#5 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 25 May 2011 - 07:28 PM
i have got cobra clubmans that are bolted to the floor but use the tilting subframe and it isnt impossible to fit in the back, but there would be near to no leg room and if you use harnesses there would be nowhere for anyone to sit anyways:)
#6 scotty_18
scotty_18
  • 884 posts
  • Local Club: LMSOC
Posted 26 May 2011 - 07:12 AM
I've got buckets with harness's and tilting it forward is impossible! the harness gets fully stretched so it stops the seat from going forward so if i need to get in the back i climb through the middle :withstupid:
#7 david_vennard
david_vennard
  • 151 posts
  • Local Club: East Coast Minis NI
Posted 26 May 2011 - 10:40 AM
it is do able its not impossible, unless your mates are slightly pudgy... now that's different
http://www.midlandwh...-Black/Red.html
there my seats what i would do move the seat all the way forward and tilt and squeeze them in always funny when they get stuck :L
very annoying getting people in to the back, that's why i'm still on the look out "when i have monies" for recaro type seats
#8 zelliott
zelliott
  • 159 posts
Posted 26 May 2011 - 12:03 PM
Ive got cobra classic's and the slide and the will lift up forwards so you can just about get in the back (:
#9 Dolly 89
Dolly 89
    Previously known as suzzy 273
  • 1,366 posts
  • Local Club: Humberside moc
Posted 26 May 2011 - 02:30 PM
this doesnt really answer your question but i take it you are planning on running bucket seats with normal seat belts and not harnesses? are you crazy?
#10 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 26 May 2011 - 02:35 PM
Nothing wrong with this as long as the strap is actually across your body and in contact with your chest waist. If you are sat back in the seat and the strap is sat against the side bolsters and not making contact with your body then you need to fit harnesses. In this case using the back seat is a no no! :)
Edited by Sleepy Stu, 26 May 2011 - 02:36 PM.
#11 Dolly 89
Dolly 89
  • 1,366 posts
Posted 26 May 2011 - 02:37 PM
i never would because when my bro had a crash in a corser he came forward and went to the side and hit his back on the side bolster of the seat and now has a knackered back for life, imagine how much worse it would be in a bucket seat with much harder sides
#12 Bannon
Bannon
  • 231 posts
  • Local Club: NEMC
Posted 26 May 2011 - 02:50 PM
I have cobra clubmans in my mini with the tilt and slide sub frames....rear access is fine if they are slid right forward first...I have standard seat belts in and they still do the job fine!
#13 Dolly 89
Dolly 89
  • 1,366 posts
Posted 26 May 2011 - 02:52 PM
Have you had a big crash whilst using them then? if not how can you say they work fine?
#14 shed
shed
  • 594 posts
Posted 26 May 2011 - 03:09 PM
i use standard seatbelts and they sit on me where they normally would with a standard seat, why the big issue?
