Mg Metro Inlet Manifold Vs Mini Sport Inlet Manifold
Posted 25 May 2011 - 10:21 PM
I have just started my engine rebuild, the engine is from a 1989 mg metro. The engine came with a Mini sport alloy water heated manifold.
I was wondering if anyone knows which one is better as i have heard good things about the mg metro manifold but i havent heard much about the minis port alloy manifold?
thanks
owen
Posted 25 May 2011 - 10:25 PM
Posted 25 May 2011 - 10:34 PM
Posted 26 May 2011 - 06:22 AM
Posted 26 May 2011 - 09:09 AM
thanks for the reply, i will try and source an original mg metro manifold and sell my mini sport alloy manifold, another question, was the mg metro manifold alloy?yes the MG manifold was water heated and was about the best flowing one you can buy
owen
Posted 26 May 2011 - 09:20 AM
Also the alloy around the water pipe was to close to the rocker cover, we had to grind that back slightly
Posted 26 May 2011 - 09:25 AM
One thing we noticed when we fitted an MG manifold to one of ours was that the outer faces of the mounting tabs on the manifold were at different height to the exhaust manifold so the thick washers didn't sit right. We made the faces all same size but I've read of others who step the washer on one side.
Thanks for your input. So, i would have modify the manifold to ensure that it would fit with a lcb manifold and to make sure it wouldnt foul the rocker cover? Were they alloy originally and also what is your oponion on the water heated side of things?
Owen
Posted 26 May 2011 - 09:38 AM
As for the water heated lots of arguments for and against. Personally mine isn't connected but to be honest that was mainly down to asthetics, I've got the old style heater circuit so would have meant an ugly pipe across the engine or a modification.
I did plumb my sisters and brother in laws in, can't say I noticed any difference between theres and mine.
Posted 26 May 2011 - 09:46 AM
I had that in mind for whatever one i had. I read through the manifold section in Vizards book and didnt see any info on the minisport manifold hence the questionStill say stick with the one you have. The MG Metro manifold was alloy and you will find it very similar if not identical to the one you have. For the outlay of the unit power gain will be miniscule if any at all. More could be gained from you buying a dremel and attacking the Minisport unit to smooth out the ports than you buying another intake manifold.
Owen
Posted 26 May 2011 - 09:57 AM
Posted 26 May 2011 - 10:19 AM
with heater connected, seems to improve fuel consumption but causes a power lose when engine is warm, i havent connected the heater. Connect the servo, if you have one..
You can improve manifold performance by removing the burrs and the casting imperfections you'll find inside, but DO NOT polish it, as it is meant to be rough on the inside to aid fuel atomization.
Edited by jaydee, 26 May 2011 - 10:21 AM.
Posted 26 May 2011 - 10:27 AM
Thanks, i havent got a servo so it dosent matter. Dilemma on what to do! I thought it might have been a copy of the Metro manifold. I would rather have the original rather than a copy and i dont like having parts stamped with shop branding e.g Mini Sport. I think i will shop around for a MG Metro manifold.The minisport inlet manifold is some kind of a reproduction of the mg inlet..i wouldnt waste money on a swap.
Owen
Posted 26 May 2011 - 10:40 AM
You can always file down the minisport logo in 5 minutes..
Posted 26 May 2011 - 10:55 AM
Owen
