Ive been offered some 7" disc brake assembly, as im running on drums alround, and still want to maintain a 10" wheel.
Do you recomend them? and if so what mods can i do to them to make them a good set of brakes without braking the bank? (excuse the pun) e.g EBC green stuff pads?
7" Brakes
JoeBodge
, Jan 15 2006 09:52 PM
6 replies to this topic
Posted 15 January 2006 - 09:52 PM
Posted 15 January 2006 - 10:03 PM
Stick with drums. You'll get far more effective braking with drums. The stopping power of 7" discs is less effective than drums of 7.5" discs.
Posted 15 January 2006 - 10:08 PM
Better than single leading shoe drums..
On a par with twin leading, but you don't have to adjust brakes
Worse than 7.5's or 8.4's
Posted 15 January 2006 - 10:11 PM
stay with what you have got unless you can find some 7.5 inch disks :smartass:
Posted 16 January 2006 - 12:12 PM
I agree with Guessworks, if you have twin leading shoe drums then stick with those and keep them adjusted. If you have single leading shoe drums then swap. If you do use these however don't think that it'll be easy to swap to bigger discs later as almost none of the parts are compatible with the later disc setups, most of the parts used on the system are from the drum setup. Only the hub-upright can be used.
Edited by Dan, 16 January 2006 - 12:12 PM.
Posted 16 January 2006 - 02:39 PM
How do i find out if i have twin leading shoes drums or single leading shoe drums?
Posted 16 January 2006 - 04:07 PM
Twin leading shoes have two pistons in the brake drum (so it pushes both sides of the shoe), and can be identified by a pipe going from the bottom of the back plate to the top.
