A Tad Confused...
Posted 27 May 2011 - 10:29 PM
Now i've been under the impression, the brake & clutch fluid is put into the one reservoir (the one with 2 wires you need to disconnect before opening), but i've just discovered theres a clutch reservoir hidden at the back, does this need to be topped up also?? or are is the fluid distributed through that one reservoir?
Posted 27 May 2011 - 10:34 PM
Posted 27 May 2011 - 10:42 PM
Posted 27 May 2011 - 10:43 PM
In a late Mini don't you get some bottle at the back.. washer bottle? or something - i don't think its brake fluid..
EDIT: Minisport7 - i think the confusion arose with 'Cooper S' - it would be a 'Cooper Sport' but not an 'S' (which is a very early mini - or a type of BMW Mini!)
Edited by Timtom, 27 May 2011 - 10:45 PM.
Posted 27 May 2011 - 10:46 PM
Posted 27 May 2011 - 10:48 PM
I'm now confused on which bottle you mean
Posted 27 May 2011 - 10:50 PM
I dunno where the clutch fluid goes
Posted 27 May 2011 - 10:53 PM
It's the one that you mention, Minisport7 - Sits on the bulkhead, in a little round "tin can" thing! Very high-tech!
Posted 27 May 2011 - 10:56 PM
Posted 27 May 2011 - 10:58 PM
Posted 27 May 2011 - 11:14 PM
what made you think that? BMW MINI started production in 2001, i clearly stated my mini is 2000 :S
Hi Minisport 7,
You should have a brake fluid reservoir sitting on the brake master cylinder sticking out of the servo above the clutch housing. This should have the two wires which is for your low level brake fluid warning light. Then you have the clutch reservoir which is fitted on the bulkhead just to the right of the brake servo when looking at the engine bay from the front of the car.
Both need topping up!
Here's a pic of mine though it's a 1989.
Posted 27 May 2011 - 11:21 PM
i don't think you're right Cooperman..
I didn't post anything - still, I suppose I can still be wrong
Posted 27 May 2011 - 11:22 PM
Posted 28 May 2011 - 01:07 AM
