1992:
When in fourth gear doing above 3000+ RPM the car runs fine, when the pedal is let go of completely (not when just letting off) it also appears to be no problems, the problem occurs when the pedal is pressed again and a plume of smoke comes out the back, its a quite big cloud, not a dark cloud and smells like oil/fuel... its hard to say. I took it to southam and they said definitivly that it was the piston oil seals, they changed these (free of charge due to buying the engine from them) but the problem is the same and the engine is also overheating quite quickly.
I hope someone can shed some light on the situation
Stage 1 kit
