Minispares sells the lower window channel 24A88 that is the original stiff rubber but the upper channel 14A7167 that they sell is flexible rubber and felt. I found references to 14A717/orig on other sites that describe it as the original stiff rubber channel.
Should I use the soft rubber upper channel or try to get it in the original stiff rubber?
Thanks,
Keith
Mk1 Sliding Window Channels
Keith Grendahl
, May 30 2011 07:11 PM
No replies to this topic
