Manifold To Downpipe Problems
Posted 31 May 2011 - 05:23 PM
upon driving, there was a sound resembling sucking air. upon checking the carburetor, air filter and housing, none of these seemed to be faulty. on closer inspection, I seem to have an exhaust blow coming from the point where the outlet manifold joins to the exhaust downpipe. because of the tight position and angles behind the main engine block, i cant get in with the tools to get it tight enough, or even if the parts join together with the clamp tight enough at all. i was wondering if there was a specialist tool, or way of tightening the joint, or if it was possible to purchase a new manifold with the downpipe all in one peice. the manifold is the type that goes into one pipe before it joins the downpipe... any help/advice/product suggestions would be hugely appreciated!
Thanks in advance, Adam:
Posted 31 May 2011 - 05:37 PM
This can be replaced with two seperate manifolds, inlet and exhaust. Basically a stage 1 kit which would give better performance and shift the join to below the engine.
something along these lines
Posted 31 May 2011 - 06:17 PM
Posted 31 May 2011 - 06:32 PM
Posted 31 May 2011 - 06:44 PM
This is a standard set up... exactly the same as my Mini 35.. basically I've found it a pig, it still blows a bit but getting the right clamp is very difficult! I'm sure my exhaust is suppose to go up the manifold taper more than it does, currently it allows for very little error in the shape!
im in the same boat as you dean... is the stage 1 exhaust blowing o the standard one?
Posted 31 May 2011 - 06:57 PM
Posted 31 May 2011 - 07:35 PM
i was thinking of getting a stage 1 kit anyway, do you know anything about fitting them?
does anyone know the benifits of installing one?
