Chrome Paint?
oliver122
, Jun 02 2011 07:16 AM
7 replies to this topic
Posted 02 June 2011 - 07:16 AM
hey guys what it is is ive got some mini lights with a dish but they have corroded and look abit naff , ive tried polish them up but with no joy , so was thinking of using chrome paint for the dish , and black for the centre, has anybody seen/used this paint before ? does anybody have any recommendations?
thanks in advance guys
Posted 02 June 2011 - 08:02 AM
I got some chrome paint from halfords. Not very nice to be honest. More of a weired silver..
Dan
Dan
Posted 02 June 2011 - 09:02 AM
I've tried a few different chrome paints before, to repair the reflectors in some spot lamps and none of them gave what i would call a chrome effect and certainly not a mirror finish, just turned out as already said a weird silver. So i ended up buying new spot lamps for about the same price as i'd already forked out on all the chrome paint
Posted 03 June 2011 - 09:52 PM
Same as, not very good. Tends to rub off as well when touched, leaving a dull lead looking finish. I tried to clear coat laquer it just to see what happened, even though it did say on the can not to & it just reacts and goes even worse. I would save you money and just get them refurbed correctly.
Posted 03 June 2011 - 10:06 PM
If you want the dish to shine again, you need to strip the lacquer off the dish and polish the metal underneath it.
The reason they look bad is usually because the lacquer has peeled and let water under it.
Posted 04 June 2011 - 12:45 PM
To be honest with you there isn't really any paints on out at the moment that actually look like chrome without spending an absolute fortune, talking £150+ per litre. The lacquer on all polished rims will eventually lift off because it has nothing to stick to. Once it gets a slight chip or mark then moisture gets in & the rest start bubbling off. You can remove the lacquer & polish them up but this means continually polishing to keep them looking good or I have had some stripped in the past & just painted them.
Posted 05 June 2011 - 10:47 AM
i dont think mine has got any lacquer on to be honest , i had a go at one of the wheels with autosol (think its that ) a polishing mop on a drill , and it didnt really touch it , then i decided to attack it with wet and dry , nothing happend with that
there my wheels ^^^ i carnt get a polish mop in properly all the way round because the spokes get in the way
cheers for the reply guys
