Buying a f reg 1275 metro on sat, anyone know if it will be unleaded or not or how to tell?
unleaded/leaded?
Andykettle
, Jan 16 2006 10:18 PM
7 replies to this topic
Posted 16 January 2006 - 10:18 PM
Posted 16 January 2006 - 10:22 PM
12he engine number
or 95 ron sticker on front panel
Posted 16 January 2006 - 10:29 PM
a F reg should be leaded unless someones converted it :smartass:
print this out and take it with you. Then you can check it against the engine number when you get there
http://www.theminifo...=post&id=153826
Posted 16 January 2006 - 10:37 PM
not all 89 metros are unleaded the same as minis i has a g reg 90 mayfair that was not unleaded
dave
dave
Posted 17 January 2006 - 12:11 AM
Yes dave is right, the changeover is late 1988, with mixed production for a bit. At the time 4 star was much cheaper than unleaded, so 4 sat cars still sold well.
We had an early unleaded 998cc Austin Metro as a garage run around for ages.
"The Metro Custard" as it was bright yellow was registered in October 1988. It even beat a Porsche 944 around a twisty backroad.
Look for the 12HE engine code if its in a Metro. That means its unleaded.
Posted 17 January 2006 - 12:38 AM
I think the actual change point is late '89 but it was available as an option from late '87 on and obviously all the over stock of the leaded cars would have taken a while to sell after they stopped manufacture. So with any car of roughly that age you'll always need to check the engine number, you can't just say yes or no based on age.
Posted 17 January 2006 - 05:25 PM
Thanks for everyone's help, will check on sat and let you know
