hi
can any one identify my distributor its fitted to a a plus 1275 the only numbers i can see are 41907A 1390 is it a d25/or 35 45 any ideas thanks
Which Dizzy
minimotivator
, Jun 04 2011 09:05 PM
3 replies to this topic
Posted 04 June 2011 - 09:05 PM
Posted 04 June 2011 - 09:31 PM
See this PDF distributor database compiled by Marcel Chichak from Canada:
http://www.mgaroadst...ation/lucas.pdf
The basic number of 41907 identifies your distributor as being originally used on post 1982 998 Metros. The other number (1390) identfies the distributor as being made the 13th week of 1990.
The database identifies your dizzy as a 59D4 type.
Posted 05 June 2011 - 08:26 PM
hi
thanks for the info on the dizzy i may try to find a better one for my 1275 a plus as this one is ment to be for 1000cc they may be different .any idea what to go for its got a ported and polished mg miget head and a kenk 286. thanks again
Posted 06 June 2011 - 12:05 PM
Hi again,
I really cannot say what would be best suited for your engine. If you have the funds, you could have your engine evaluated on a rolling-road and have them determine your optimum advance curve. Once you know that I believe you could have a distributor shop "re-curve" your distributor to provide the advance curve your engine needs. You will also see a lot of people on this forum bring up MegaJolt. That is a programmable ignition system which does away with the distributor and allows you to "map" an ignition curve suited to your engine. I know little about the, but there are lots of threads on this board that you can read through to learn more.
