Alternator Earth
Posted 06 June 2011 - 09:46 PM
Problem is though I have fitted a new 70amp alternator that has an earth stud but I cannot find a wire suitable with a ring tongue on that looks like an earth, should there be one or is it not needed.
Posted 07 June 2011 - 12:03 AM
Posted 07 June 2011 - 10:03 AM
Posted 07 June 2011 - 10:30 AM
Posted 07 June 2011 - 10:57 AM
Posted 07 June 2011 - 11:54 AM
http://cgi.ebay.co.u...=item2ea94ac504
It is normally fitted to mk4 escorts such as XR3i, it actually has 2 studs on it, I know if you search for a Lucas A127 on Ebay it comes up with a similar version for marine applications so maybe the studs are there for this purpose. Just for information the connector is exactly the same as the standard mini 3 terminal connector.
Posted 07 June 2011 - 12:01 PM
On mine there is the standard 3 pin (2 big, 1 small) connector. But also an additional 6mm stud connector which is optional to use.
Posted 07 June 2011 - 12:09 PM
Yes as above, some of the 70amp alternators have an additional 6mm stud which is 12volt live.
I'm running same alternator. No need for a seperate earth lead.
So is this stud definately a 12v live supply
Posted 07 June 2011 - 12:11 PM
Posted 07 June 2011 - 12:13 PM
Figured if uprating alternator may as well stick an additional charge wire in considering 1984 wiring wasn't made for a 70amp alternator.
Posted 07 June 2011 - 12:14 PM
Looking at the 2nd pic down the stud on the right has an insulated washer on the terminal so would not be an earth stud. Dont connect it to earth!
No I'm going to leave it as Irostoke said as it may be a 12v supply, if I have charging probs later I know where to look
Posted 07 June 2011 - 12:24 PM
The threaded stud to the right (at the 3:00 o'clock position) clearly has insulators on it. That WILL be a +12V output.
EDIT: Strikeout last paragraph as incorrect.
Posted 07 June 2011 - 01:31 PM
The M6 output lug can be used to connect a heavy guage cable from the solenoid + to the alternator... provides a better connection than the plug.. (or use both!)
Edited by icklemini, 07 June 2011 - 01:33 PM.
Posted 07 June 2011 - 03:16 PM
The eBay link does specify that the M5 stud is "W" which would mean "phase" and agree with AD Dodds picture above.
Thanks for catching that!
Posted 07 June 2011 - 03:23 PM
As per AC's handy diagram:
I stand corrected and will edit my last post.
Yes both of the studs have rubber insulating washers to isolate the casing
