Im changing mine to the later 'click' to lock type instead of twist to lock. But its got a plastic body, no thread/nut, how does this fasten to the switch panel? :S
Late choke cable fixing
rob3
, Jan 17 2006 06:59 PM
4 replies to this topic
Posted 17 January 2006 - 06:59 PM
Posted 17 January 2006 - 07:17 PM
You need a new late switch panel, switch panel bracket and retaining clip. The cable fits through a larger, D - shaped hole in the new panel, and through the bracket the same way as the early cable is fitted and is retained there by a spring clip which slides into the groove in the cable outer.
Posted 17 January 2006 - 07:28 PM
Any ideas on a part number for retaining clip? / bracket?
Posted 17 January 2006 - 07:31 PM
Found the clip : ADU5065
No idea on the new bracket tho
Posted 17 January 2006 - 07:48 PM
The bracket is really hard to find, you might need to get it from a scrapper or you might get away with enlarging the hole in the existing bracket. It does really need to be the right one though as otherwise the panel will be a sloppy fit to the car and will move about when you use the choke.
