Hi everyone,
I'm after a new down pipe (from the manifold to the cat) for my '97 MPI. The flexible joing has cracked after hitting one too many speed bumps.
Mini spares have two available,
Standard - GEX12043
and a different one (which is part of the stage 1 kit) - C-AEG371
Does anyone know if the stage 1 kit one (C-AEG371) is in stainless steel or not? Or are you just paying the extra because it is described as having a better flow than the standard one?
I fancy fitting a stainless one as I also have a stainless RC40 from the cat back. Dont expect any performance gains but it should last longer.
Thanks.
Stainless Steel Down Pipe?
gbt100
, Jun 08 2011 06:08 PM
3 replies to this topic
Posted 08 June 2011 - 06:08 PM
Posted 09 June 2011 - 08:59 PM
To be perfectly honest I would stick with the orginal MPI manifold and downpipe
The mpi has a LCB fitted as standard and has the correct place for the Lambda sensor to be placed.
The other alternative is the maniflow LCB manifold but this only reads the lambda from the outer 2 cylenders. And on past experience this can play havoc with the emissions.
Mike
Mike
Posted 11 June 2011 - 03:03 PM
No it doesn't, long centre branch. The manifold is not longThe mpi has a LCB fitted as standard
Posted 13 June 2011 - 07:26 PM
The MPi has a cast iron manifold as standard and then a twin downpipe that merges into one before the knuckle joint.
Althought the Maniflow LCB will give better performance it also sits lower to the ground and many has said that there exhausts hang lower resulting in it hitting speed bumps etc.
