Torque Converter
Posted 09 June 2011 - 01:24 PM
has anyone had this problem and could it be anything else as a secondhand checked one is 250 quid and i dont want to waste my money getting something i dont need any help would be nice
Posted 09 June 2011 - 01:46 PM
There's good advice on checking the oil and what oil to use here: http://www.mra-minis...mini/automatic/
hth, Paul
Posted 09 June 2011 - 01:57 PM
Posted 09 June 2011 - 02:05 PM
Could always splash out on a new one........
Posted 09 June 2011 - 02:30 PM
Posted 09 June 2011 - 03:32 PM
Posted 09 June 2011 - 03:34 PM
Posted 09 June 2011 - 03:36 PM
I just read your other topic about the carb and poor performance. My 998 auto will do more than 62 mph! You really need to get this sorted before you splash out your hard-earned cash on a replacement torque converter.
yep iv put on a hif44 carb sounds a lot better but now i can not find out if its worked
Posted 09 June 2011 - 03:48 PM
done all that turned the tickover right up and down on 1/2 turns trying to get drive disconected both cables to choke and excel incase they were interfering still no joyIs the engine running and idling OK (not too fast) when in park and neutral? A poorly running engine may cause the same problem. With any auto transmission problem it's always a good idea to change the oil if it's been in for a while and make sure that it's topped up correctly.
hth, Paul
