Mini Clubman Overheating
8 replies to this topic
#1 daenesh
daenesh
  • 423 posts
  • Local Club: Classic Car Owners Group
Posted 11 June 2011 - 05:37 AM
hey guys, i've been having this problem with my mini especially when i on the air conditioning.. i have fitting an external fan that runs all the time and the original belted fan is running clean and smoothly as well.. the radiator has been changed to a 3 core one as well.. using the correct rad cap.. yet when im driving with the air cond on in normal roads at speeds of 60-70km/30-40miles the temperature gauge shows half or below half.. but once i get onto the highway/motorway and reach speeds of 90-100km/h or 50-60miles an hour the temperature goes slightly above normal to almost 3/4 of the gauge.. here a picture below.. pls have a look and give me some advice regarding this problem.. i do not have a thermostat as i live in malaysia which is hot and also my water pump seems to be shooting water out well.. pls help me guys would really appreciate it and sorry for the long long explanation.. thanks
daenesh
#2 new_zealand _minis
new_zealand _minis
  • 654 posts
  • Local Club: wellington new zealand
Posted 11 June 2011 - 06:10 AM
well with no thermostat . it shuld not get hot at all . .
so it only shows hot on the guage ?... is the radiator really hot . if its not boiling over and spewing out . i would not worry
#3 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 11 June 2011 - 06:11 AM
having your water pump spit water out wont help things mate, get this sorted, and it should improve things, temperatures like you are showing aren't bad, as you say you live in a hot country, its expected! so sort the water pump and you will see the benefits :)
hope this helps!
#4 daenesh
daenesh
  • 423 posts
Posted 11 June 2011 - 06:18 AM
thanks for the quick replies guys.. but theres nothing wrong with my water pump wad i meant was that when i took the top hose out and ran the car.. the water pump was shooting the water out nice and strong which indicates the pump is working fine.. although i can't be sure if it works fine under highway driving.. any other suggestions guys?
#5 daenesh
daenesh
  • 423 posts
Posted 11 June 2011 - 06:21 AM
yeah its not spewing out water nor is it boiling i guess.. the radiator is very hot but i need to use a thermostat to actually see how many degrees it is.. maybe later i will check the temperature and i will let you guys know.. thanks
#6 daenesh
daenesh
  • 423 posts
Posted 11 June 2011 - 07:14 AM
anymore suggestions guys?
#7 daenesh
daenesh
  • 423 posts
Posted 11 June 2011 - 05:06 PM
the hottest temperature it reaches is 92 degrees Celsius.. is that very high?
#8 dossy
dossy
  • 271 posts
  • Local Club: Suggestions for North Yorks?
Posted 11 June 2011 - 05:31 PM
Dont thinks that's mad high considering where u live, think mine runs around 88-89 usually? Don't quote me, just sticks in my head for some reason?!
#9 daenesh
daenesh
  • 423 posts
Posted 12 June 2011 - 02:41 PM
ic ic .. im just worried sometimes tats all.. because most of the people here in malaysia who drive minis they stay with the similar setup their temperature goes to a max of half..
