Model: 1275 cooper
Year: 196?
Need to replace the inline brake light pressure switch.
I have no removal/installation advice but I do have a question and some information.
Are replacing the switch because it has failed AND you are using DOT-5 (silicone) brake fluid? If so, you may be wasting your time replacing the switch. There are many, many reports over the years of the hydraulic brake light switches (even brand new ones) failing after a short exposure to DOT-5 fluid. The work-around is easy. Buy a pedal actuated switch as used on later cars and rig up a mounting bracket to use it instead. Run two wires from the pedal switch through the firewall and plug them into the two wires that now go to the hydraulic switch.
