What symptoms did you suffer and what's your story?
Come on, don't be shy......need some feedback here.
Edited by skalypsotone, 13 June 2011 - 11:59 PM.
Posted 13 June 2011 - 11:22 PM
Posted 14 June 2011 - 12:55 AM
Edited by Costy, 14 June 2011 - 01:18 AM.
Posted 14 June 2011 - 01:55 PM
So, I'm interested in anyone who has experienced sypmtoms related to a faulty (not actually failed) crank sensor.
Posted 15 June 2011 - 09:27 PM
Mine went bad, but took over a year to figure it out, $3,400. and 8 months at a "specialist" shop, I posted videos and described my problems on the forums and it was solved, Thanks again !.
http://www.theminifo...howtopic=179523So, I'm interested in anyone who has experienced sypmtoms related to a faulty (not actually failed) crank sensor.
Posted 16 June 2011 - 01:15 PM
Posted 27 June 2011 - 05:09 PM
Posted 27 June 2011 - 06:54 PM
My crank sensor was faulty, the car would start and be fine for about 10 mins till it warmed up and the contacts of the sensor would get hot and distort, this made it cough splutter misfire, go out of time and generally be completely undriveable!
Posted 27 June 2011 - 08:51 PM
Posted 25 April 2016 - 05:34 PM
Posted 01 May 2016 - 03:43 PM
To me it sounds you guys never check and clean that sensor. Mine was dirty and oily.
It is the same with CTS which collects dirt and calcium layers from the water and then signals not correct values to the ECU.
Edited by Alpenflitzer, 01 May 2016 - 03:44 PM.
