Mpi Etc Steering Wheel
7 replies to this topic
#1 Lewis998
Lewis998
    Previously known as SCYLLA
  • 243 posts
Posted 13 June 2011 - 11:34 PM
Hi all. I know that you have to change the steering column when you want to fit an MPI wheel to a pre injection mini, I was wondering if anyone can tell me,
A: what else needs to be done to fit one ?
B: do these changes have to take place to fit and an MG F steering wheel or other MG wheels ?
Any info is appreciated
#2 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 14 June 2011 - 06:37 AM
Hi
You need to change the column complete
You will need the later mounting bracket for the dash rail
Stalks (can use MGF ones - Cheaper)
Wheel (can use MGF one - Cheaper) - Recommend removing airbag for safety
Slipper ring for horn connection (will need to use a relay for the horn)
MPI steering lock
MPI cowl
Part of the wiring loom (stalks end) will make the job much easier
You will need to play around with the wiper wiring a little and move the wiring for the lights from the switch to the stalk.
Drop a PM to R1minimagic as he had an MPI column for sale the other day & may have some of the other bits.
Some detail in my project pages or drop me a PM and if I can help, I will.
Regards
Steve
#3 R1minimagic
R1minimagic
  • 4,660 posts
Posted 14 June 2011 - 08:55 AM
Hi,
I have everything apart form the steering wheel and ignition barrel but will probably have another MPi next week so should have everything.
Dale
#4 minilester
minilester
  • 770 posts
Posted 14 June 2011 - 09:34 AM
Hi
MPI steering lock
MPI cowl
Regards
Steve
so if he converted to an MPi steering colum you can use the electrics from the MGF?
#5 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 14 June 2011 - 01:49 PM
Hi
MPI steering lock
MPI cowl
Regards
Steve
Stalks for the MGF are the same as the MPI
#6 Lewis998
Lewis998
  • 243 posts
Posted 14 June 2011 - 08:55 PM
Great stuff guys, thanks for the reply's, going to have to wait till I can get some more spare cash together, was just looking in to what would have to be done when I get a chance to do it all
#7 M44K TS
M44K TS
  • 3,104 posts
Posted 15 June 2011 - 04:49 PM
Even cheaper than MGF ones, Rover 200, 25, 400 MG ZR, ZR van, MG ZS, Honda Accord saloon, EG Civic, (if you want the lights and wipers on the opposite side to normal)
They all use the same style stalks as the MPI
#8 Lewis998
Lewis998
  • 243 posts
Posted 19 June 2011 - 05:18 PM
Cracking, thanks for that man
