Fuel Temp Sensor/switch?
Posted 14 June 2011 - 07:50 PM
she said that it was a fuel temperature sensor/switch that was causing the high idle that the car has been experiencing on start up.
does any one know where the location of this sensor is? or if it exists at all? any help is greatly appreciated.
Posted 14 June 2011 - 10:18 PM
If this was highlighted by a diagnostic, they tend to sometimes show 'fault' codes for stuff that just isn't there, since the diagnostic software is designed to cater For the whole Rover model range, not just the Mini.
Edited by Sprocket, 14 June 2011 - 10:18 PM.
Posted 15 June 2011 - 10:51 AM
Posted 15 June 2011 - 11:58 AM
Perhaps if you post us a photo of the random stranger we could perhaps open a forum vote to determine how hot she is
Posted 22 June 2011 - 09:51 PM
Posted 22 June 2011 - 10:07 PM
My 1997 MPI Revs at 1200rpm when firing up from stone cold.. But then drops back to 800rpm when warm.. i've always thought this was a normal thing
I would think this is the automatic choke
Posted 22 June 2011 - 10:10 PM
Sounds like it mate, i can tell with mine as mine overfuels for 10 mins and smells my driverway out as i ditched at Cat lol
Posted 23 June 2011 - 06:28 AM
Mine runs at 1200rpm at least at all times! I also thought it was normal as he's been doing it for over 2 years :/
Posted 23 June 2011 - 12:20 PM
Every engine is set differently I guess but 1200rpm tick over does sound quite high. Is yours running rich?
Posted 23 June 2011 - 12:29 PM
I believe so, yes. How will I know for sure?
Posted 23 June 2011 - 12:55 PM
Start the engine (in a garage if possible) walk round the bacck to your exhaust take a good sniff and if it really smells like half burnt petrol that means its really rich
Posted 25 June 2011 - 03:56 PM
Having had some experience with random strangers, particularly female ones, I find I sometimes have to translate their meaning. Now as Sprocket rightly points out there is no fuel temp sensor. There is however a COOLANT TEMPERATURE SENSOR, which has a very large effect on idle speed. So do you think this is what she meant. Perhaps if you post us a photo of the random stranger we could perhaps open a forum vote to determine how hot she is
In fact you were right... I told her I had never heard of a fuel temp sensor, but she was insistent (and not that hot). we eventually found that the wire to the temp sensor was grounded... cleaned up the wiring and the problem is solved!
