Oil Leaking From Front Of Engine
13 replies to this topic
#1 wardyxxx
wardyxxx
  • 1,327 posts
  • Local Club: Leicester Mini Club
Posted 15 June 2011 - 06:51 PM
Basically, the mini has started leaking oil from a round plug in the front center of the engine block.
Fixable? How to?
Thank you muchly.
Edit: can get photos if needed.
Edited by wardyxxx, 15 June 2011 - 06:54 PM.
#2 the_r_sole
the_r_sole
  • 831 posts
Posted 15 June 2011 - 07:06 PM
same as this one? http://www.theminifo...x...=189704&hl=
mine just needed a wee tighten up
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 15 June 2011 - 07:31 PM
Picture...
#4 wardyxxx
wardyxxx
  • 1,327 posts
Posted 15 June 2011 - 08:21 PM
Here, behind the dip stick.
[attachment=113586:photo.JPG]
#5 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 15 June 2011 - 08:45 PM
That is a core plug for the water jacket, not oil.
If it is leaking, it will need replacing. The plugs are cheap enough, but although fitting them is an easy process it can be tricky, but not impossible, with the engine in the car.
#6 wardyxxx
wardyxxx
  • 1,327 posts
Posted 15 June 2011 - 08:48 PM
It's definately oil. Cleaned it all off yesterday and checked today whilst the engine was running.
Not sure where it could be from if that's A core plug.
#7 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 15 June 2011 - 08:54 PM
Might be peeing out your dipstick and just looks like its coming from the core plug? My dipstick leaks oil like nobodies business!
#8 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 15 June 2011 - 08:59 PM
Are you definitely sure its coming from behind the dipstick and not shooting up from the dipstick itself?
Also over to the left of it as below in link provided above
Is that your engine bay in the picture you posted in your reply?
#9 wardyxxx
wardyxxx
  • 1,327 posts
Posted 15 June 2011 - 09:12 PM
Nah, not my pic. It's the the garage and if I want to live I'll wait until tomorrow to take a pic.
I thought about the dipstick, but I thought that was daft! All around the dipstick is covered too.
So what's the first port of call? New dipstick?
#10 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 15 June 2011 - 09:15 PM
A big spring from the oil pipe to the dipstick loop to hold it down. Thats the cheapo method.I keep meaning to do it... Or just get a new dispstick from Huddersfield or the likes.
#11 wardyxxx
wardyxxx
  • 1,327 posts
Posted 15 June 2011 - 09:21 PM
I'll get one ordered!
#12 Kam
Kam
  • 4,140 posts
Posted 15 June 2011 - 09:34 PM
Nah, not my pic
Ahhh ok, that makes sense, I was gonna mention that someones nicked your ecu :)
Cheapest would be to clean up the front of the engine as best as you can, not just behind the dipstick or the rubber on the dipstick but all over the front, start it up and check for leaks
#13 Trick77
Trick77
  • 136 posts
  • Local Club: DCMOC
Posted 16 June 2011 - 11:36 AM
DSN Classics do a dipstick retaining spring to hold the dipstick in under high oil pressures
http://www.dsnclassi...y_Parts_33.html
http://www.dsnclassi.../info_1027.html
Edited by Trick77, 16 June 2011 - 11:37 AM.
#14 wardyxxx
wardyxxx
  • 1,327 posts
Posted 18 June 2011 - 04:10 PM
Its the front core plug "it's easy enough to pop out and put a new one in" - mate at a garage.
At least the mini passes the MOT, knew it would. Just got one advisory.
