I just continued the refurb of my 12g295 head to put on my 1098.
I had exhaust valves for a 12g202 head, with single grooves. It took me some searching to source inlet valves, now these have triple groove.
I test fitted them to the head, after putting on new guides and lapping in.
Only now I have noted the valve stems are not equally long, and that I possibly have a problem with the collets.
See picture.Visit My Website
You can see one spring is a lot more compressed than the other.
Does anyone know if I should get other exhaust valves for a 295 head ? Did I get the wrong inlet valves ( for a 1275 perhaps ? ) Did I combine the wrong collets wit hthe wrong spring cap ?
EDIT : okay, I already found out the valves are 94 mm long, where the inlet valves for my 202 head and the exhaust valves are only 86, could it be I was sold large bore valves instead of small bore ?
AM I right in assuming the long valves are for 1275 cc engines ?
Edited by Fluffy, 16 June 2011 - 07:27 PM.
