Dead As A Dodo (not Starting Or Ticking)
Posted 20 June 2011 - 06:56 PM
1989:
Hi everyone this is my first topic on this forum, basicly i picked up my first mini yesterday, the seller drove it to my house and i started it first thing this morning, me being stupid left the lights on dim all day untill this evening, now when i go to start the car i get nothing at all, no tick/click/noise no lights work nor does the horn. Now i know this is basic dead battery but i had it connected with jump leads for around 15mins straight to my partners C2 and still i get nothing at all, not even the hazard lights, the only flicker of life i get is the brake fluid switch test. the car is factory and not a single thing changed, but please bear in mind i am new to the world of minis so may need a bit more explanation then others.
Thanks all
Anthony
Posted 20 June 2011 - 07:01 PM
Make sure everything else is switched off heater fan light radio etc.
Then if the ignition light is bright, get the GF to rev her car up to about 3000 RPM and you start the Mini.
Posted 20 June 2011 - 08:01 PM
Put the jump leads on and start the GF's car up and let it run for about 5 mins. Then test that when you switch on the Mini the ignition light comes on DON'T TRY TO START IT YET.
Still nothing the ignition light is on (im not sure if its bright because im unsure of what bright for this light is)
when i turn the key i still get nothing at all no sound at all
p.s i forgot to mention that its an auto so no bump starting
Posted 20 June 2011 - 10:24 PM
Posted 21 June 2011 - 10:08 AM
Posted 21 June 2011 - 06:28 PM
and no i dont have a voltmeter unfortuantly
Posted 21 June 2011 - 06:44 PM
Posted 21 June 2011 - 08:07 PM
Check the fluid level in your car's battery and top the cells up with water if necessary. Tap the terminals of the battery (lightly) with a hammer to dislodge heavy sulfate deposits on the internal plates. Then charge the battery on "high" while you babysit the process. Monitor the current gauge and give the battery about 2 hours of high-current charging. Then try to start your Mini.
Failing that, try Gulfclubby's suggestion of using another battery after completely removing the suspect one from your car.
Posted 21 June 2011 - 08:13 PM
Posted 21 June 2011 - 08:45 PM
Posted 21 June 2011 - 08:47 PM
If you do not see a drop off in charging soon, you may want to take the battery to a shop and see what they say about its condition. It could just be that the battery has reached the end of its life and will no longer take a charge.
Posted 21 June 2011 - 09:05 PM
Turns out the starter motor was stuck. Try banging the starter motor! I had the exact same symptoms
just a suggestion
Posted 21 June 2011 - 11:46 PM
Good point.If you do not see a drop off in charging soon, you may want to take the battery to a shop and see what they say about its condition.
Halfords charged my battery for free and got it back to 99%. Lavely jabbly.
Posted 22 June 2011 - 12:05 PM
Okay so i went down to halfords with it and within a matter of seconds the guy behind the counter said its dead and will be £113.99 for a new one
again its a 1989 Mini Thirty Auto thanks all
Posted 22 June 2011 - 12:09 PM
Okay so i went down to halfords with it and within a matter of seconds the guy behind the counter said its dead and will be £113.99 for a new oneso he wrote the code down as HCB075 Not sure if he was possitive as the battery had seen better days, could anyone confirm this is the battery i need?
DON'T DO IT!!! www.tanya.co.uk supply batteries overnite at 40% the cost. Measure the dimensions and take a note of the posts, then look them up on the web. arrives fully charged the next day.
http://www.tayna.co....5CCA-P8396.html
Edited by Cater_Racer, 22 June 2011 - 12:11 PM.
