Spit Info
10 replies to this topic
#1 micrawavewindow
micrawavewindow
  • 609 posts
Posted 21 June 2011 - 09:52 PM
ok so i have nearly finished my new spit... i am just a little bit concerned.... how do i actually lift it onto the spit is it just a case of brute force or is a there a special way please help as i dont want to break my spit or my mini or my back cheers
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 21 June 2011 - 10:03 PM
We used a trolley jack and axle stands.
#3 grahama
grahama
  • 2,442 posts
Posted 22 June 2011 - 09:21 AM
Hi,
as long as the mini is a shell you can, if you are moderately gifted in the muscle dept, lift one end on and then do the other. Mine is on and off all the time due to working outside and I have to do it on my own mosy of the time.
Graham
#4 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 22 June 2011 - 11:17 AM
just lift it onto a few wheels and then u should be able to lift it that little bit further without all the strain of lifting it from the ground
#5 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 22 June 2011 - 12:10 PM
I jacked the shell up just above the normal spit height. Then lowered it onto the spit frames.
#6 Brams96
Brams96
  • 2,308 posts
Posted 06 November 2011 - 06:52 PM
Dragging up an old thread....
How do you get the shell centered on the spit so it is neutrally balanced? As in when you roll it, it doesn't want to roll back to it's up right position. Are there any measurements I need to know or is it just a case of trial & error with spacers to get it right?
#7 Carlos W
Carlos W
  • 10,114 posts
Posted 06 November 2011 - 06:54 PM
Where abouts in Kent are you Brams? You can come and see mine if you want!
#8 Brams96
Brams96
  • 2,308 posts
Posted 06 November 2011 - 07:01 PM
I'm in Canterbury & work in Maidstone, where are you?
Also what is the best length pole so it's long enough to take the car but not take up too much room in the garage?
#9 Carlos W
Carlos W
  • 10,114 posts
Posted 06 November 2011 - 07:03 PM
I live in Sittingbourne, presumably you come along the A249 every day!
I've got a scaffolding pole in the garage you can have to run through the centre of the car!
My car isn't perfectly balanced, but you are more than welcome to come and see what I've done!
#10 Brams96
Brams96
  • 2,308 posts
Posted 06 November 2011 - 07:05 PM
Yeah I go A2, A249 & M20 to work. I'll PM you.
#11 Carlos W
Carlos W
  • 10,114 posts
Posted 06 November 2011 - 07:06 PM
cool cool
