Big Cam Or No Big Cam..?
9 replies to this topic
#1 samsteryfc
samsteryfc
  • 79 posts
Posted 25 June 2011 - 08:33 PM
Hi all, I have an MPi Sportspack with a standard head and camshaft but I'm interested in giving a bit more get up and go. Would anyone recommend getting a beefier cam and if so which one? Or will it send my ECU round the twist? Cheers Sam.
#2 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 25 June 2011 - 10:05 PM
There are only a handfull of cams available for the MPi since it has the cam sensor instead of the fuel pump lobe.
two cams come to mond but there may be others doone by the usual big name tuning companies.
Kent cams MD274 or MD274SP and the Swiftune SW5
The SW5 is a VERY good comprimise, with the Kent MD274 a little wilder. The MD274SP is the absolute max you should go for, and needs presice engine set up to get it to work correctly.
#3 samsteryfc
samsteryfc
  • 79 posts
Posted 25 June 2011 - 10:10 PM
I was actually looking at an MD274 Cam. What needs to be altered/tuned to get the best from this and roughley how much would it cost allin for cam, tuning,labour etc?
#4 Sprocket
Sprocket
  • 7,266 posts
Posted 26 June 2011 - 07:56 PM
No idea on cost, but the Kent MD274 cam will be fine so long as it is timed in perfectly when installed, don't just fit the standard timing gears without checking. By all means use the standard timing gears, as they are more than up to the job against popular belief, but do use offset woodruf keys to get the timing spot on. The only other thing to set is the vave clearance, and make sure they are all set to specification. Kent Cams website has all this information available. There should be no real need to do anything else.
#5 mykweb
mykweb
  • 543 posts
  • Local Club: does here count :)
Posted 27 June 2011 - 08:15 AM
I had the SW5i cam in my MPi and I could not fault it. Great rev range, and awsum pull. I purchased the kit with the Duplex timing chain.
Combined it with a set of 1.5.1 rockers on a standard MPi head and it was awsum. I then upgraded to the stage 3 head and it was even better.
Mike
#6 samsteryfc
samsteryfc
  • 79 posts
Posted 27 June 2011 - 10:14 AM
Mike
Looking on the website there doesn't seem to be an SW5i only SW5-07 cam/duplex kit, but it says that is MPI specific
#7 mykweb
mykweb
  • 543 posts
Posted 27 June 2011 - 11:27 AM
That is the one :)
Mike
#8 brivinci
brivinci
  • 1,210 posts
Posted 27 June 2011 - 06:43 PM
I have the SW5-07 in my SPi now. What a great product! Cant say enough about it. I went with the lightened duplex adjustable timing set, dual springs and followers. I really took my time to get the timing as near perfect as I could. I used a dial gauge and a timing wheel to set it to 107 degrees. That is what is recommended from Swiftune.
Got rid of that terrible lack of life after 5k for me. Maybe it was even lower then that. Revs pretty clean up to...not really sure. Havent hit a limit yet:-)
#9 gora
gora
    Starting My Mini Up
  • 2 posts
Posted 30 June 2016 - 09:43 PM
hello, the md274sp will work on a MPI?
#10 jamesquintin
jamesquintin
  • 1,017 posts
Posted 02 July 2016 - 03:13 PM
I have the Cooper S Kit form Minisport and I'm getting 85bhp. The one thing that is holding it back is the gearing. Its geared for motorways so not great on acceleration. You have to be pulling over 2k rpm to feel the power...
