What Engine Hoist?
8 replies to this topic
#1 coopedup1980
coopedup1980
  • 117 posts
  • Local Club: Clubbing seals
Posted 27 June 2011 - 08:45 AM
Model: Sprite
Year: 93
Description of problem (please be as in depth as possible): Need to remove engine for gearbox repair/over haul
I've got a few issues with the mini, one of which is the gear box starting to faulter. Having hoped to get all work done by a garage the total cost is too steep (due to labour costs) and they all need doing to get it back on the road safely.
So. What is a good home DIY type hoist that has enough lift range to pick up the mini block? Can't use a suspended hoist as the beams in the garage just wouldn't take it.
Can the gear box me removed whilst suspended or is a work bench needed? Fear not, I'll not be doing the GBox overhaul.
Many thanks,
Neil
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 27 June 2011 - 08:48 AM
The power unit is about 150 Kg, any hoist should be able to lift it really.
#3 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 27 June 2011 - 11:55 AM
Any engine crane should do the job.
#4 bmcecosse
bmcecosse
  • 9,699 posts
Posted 27 June 2011 - 12:01 PM
I use an old kids swing frame - centre top bar widened with a thicker tube ex scaffolding. I bought a simple hand pull hoist for 3$ in Canada - it works very well! But in fact - the engine can be lifted out by hand, leaving the box behind - and then an easy job to lift the box out if you have no hoist at all.
#5 Cooperman
  • 23,359 posts
Posted 27 June 2011 - 12:23 PM
I use a Clarke CFC100 which is absolutely ideal and very safe abd easy to use. Cosy about £160 new, but you may find one cheaper on ebay.
#6 Nu2mini
Nu2mini
  • 442 posts
Posted 27 June 2011 - 03:55 PM
Just thought I might ask a supplementary question on this subject (as I'm also looking at engine out)
Has anyone used the modern engine levellers (Load Leveller) for a mini engine/transmission out. Would the job be easier with one. I know there is an old sykes and pickavant tool which still appear on e-bay from time to time. Just conceren that I need to tilt engine as its coming up and would like to control it. The engine leveller may only help left to right whereas I think I need to control fore and aft. Am I correct.
Well that's something I've not heard before. Given you need to get the flywheel off is it more trouble than it's worth attempting this type of lift. Surely seperating the engine from the transmission becomes a whole lot easier with the lump out
#7 SolarB
SolarB
  • 1,399 posts
Posted 27 June 2011 - 06:28 PM
I use old seatbelts looped around the clutch cover and the radiator bracket.
Attached File  P1130186_b.JPG   214.33K   14 downloads
Works an absolute treat when you need to adjust the angle.
#8 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 27 June 2011 - 06:38 PM
i use an old medical hoist for getting fatties out of baths and stuff, cost naff all and is rated to 150kg, folds away a lot smaller than the normal big engine cranes too :)
#9 not for sale sorry
not for sale sorry
  • 344 posts
Posted 27 June 2011 - 08:43 PM
try a local hire shop if your not useing it all the time and just want it the once of thats what i did/do i i want to take my engine out
